Racetronix Fuel Pump, Who is using it & what mods needed? - Page 5 - Performance Forum
Re: Racetronix Fuel Pump, Who is using it & what mods needed?
Wednesday, December 24, 2008 6:41 AM
You boosted guys should look into a return style fuel system also if you're looking for some more power.
Idk how your guys' flow, but I know on the redlines we're not even utilizing our 4th cylinder fully unless we get a return style fuel system.
Just a thought I thought I'd put out there.
http://www.ottperformance.com/Cobalt/Ion-Fuel-Systems/c2_20/p24/Return-fuel-system-kit/product_info.html
Lols.
Wednesday, December 24, 2008 7:46 AM
WHITECAVY wrote:
-MD- LD9 wrote:looks like I'll need a new tank possibly.
How come Mike?
Rusted to @!#$! I guess all those winters it saw took a toll on it.
daythecountrydied21 ok wrote:You boosted guys should look into a return style fuel system also if you're looking for some more power.
Wednesday, December 24, 2008 7:50 AM
Oh ok, so your still keepin the metal one though?
Wednesday, December 24, 2008 8:30 AM
Brand spanking new metal tank is $145 from autozone.
Wednesday, December 24, 2008 9:46 AM
Maybe I'm not understanding what you meant, but our systems are return style system
Wednesday, December 24, 2008 11:30 AM
-MD- LD9 wrote:Brand spanking new metal tank is $145 from autozone.
I didn't think it was that much. I may have to visit a junkyard for a plastic one
Jason
99 Z24 Supercharged
157hp/171tq - NA
190hp/170tq @ 6psi
LD9 for Life
Wednesday, December 24, 2008 12:07 PM
I have a plastic tank out of a 02 turbo ecotec, and 1 or 2 metal tanks in good shape. Just not sure about shipping.
Wednesday, December 24, 2008 8:04 PM
wow! you really do NOT have anything to contribute to our forum, once again.
jmarks82 wrote:
Airtonics wrote:
jmarks82 wrote:Very nice. If you don't mind me asking why didn't you use the wiring harness?? That gets rid of the voltage drop that occurs with the stock wiring.
Really it's not necessary. I have an electronic fuel gauge inside the car and I didn't use the add'l wiring either. My stock fuel pressure regulator raises the fuel press 1psi per psi of boost and the pump holds 55psi all the way to 8200 rpm without issue. Plus no fuel cut, I couldn't be happier....
I was just asking why he didn't use it because he did buy it lol. I am trying to feed 500hp. Sure its easy to wire in your own relay but this is plug and play and thats what ppl want.
I agree its not needed but its nice to have.
i'm noticing some lean spikes, not sure what is causing it, either pump wiring or tune. will prob work on it come spring. i think it was cheaper to buy pump and harness now instead of buyin them separate. and then not havin the harness if i did need it, would have delayed me gettin back on the road.
Edited 1 time(s). Last edited Wednesday, December 24, 2008 8:06 PM
____________________________________________________________________________
my carDomain updated 8/2/08 Boosted at B-day!
Saturday, December 27, 2008 6:06 PM
Working one getting rusted to hell bolts that hold the straps on....out.
BTW did you know the rubber hose between the filler tube and tank costs $68!
Monday, December 29, 2008 3:03 PM
@!#$ the tank strap bolts. That is all.
13mm bolt head and 15mm nut.
Also, I guess I have been running around on front brakes...since the back lines are rusted through.
Edited 2 time(s). Last edited Monday, December 29, 2008 3:06 PM
Monday, December 29, 2008 6:21 PM
-MD- LD9 wrote:@!#$ the tank strap bolts. That is all.
I ended up saying the same damn thing getting mine out... I ended up using some tin snips and cut the straps, removed the tank and went at the bolts with an angle grinder. Mine weren't even budging. I am painting the new straps and using SS bolts and nuts. I'm not playing that game again... ha ha.
Tuesday, January 06, 2009 9:05 AM
Waiting on my SS bolts, nuts, and washers....also waiting on the rubber hose that goes from the tank to the filler hose to come in.
Tuesday, January 06, 2009 2:12 PM
Well did you at least get the pump in the tank?
Wednesday, January 07, 2009 3:29 AM
Not yet. I be stuck at work....doing that work BS thing. Like I am now.
I hope to finish this weekend.
Wednesday, January 07, 2009 12:23 PM
what do you need to switch to a plastic pump?(any special brackets?) where can you find one?
Wednesday, January 07, 2009 12:44 PM
lmao, just got off work, and i barely slept last night...tank, not pump
Thursday, January 08, 2009 7:21 PM
So I get this email from GM your part...22649607.....is on national back order and no one knows when or if it will be off back order. It is the rubber hose that goes between the tank and the filler neck. Any help or if anyone has a 99 one....or knows of one that will fit I would be VERY happy to buy it off you.
Need number 12....
Friday, January 09, 2009 6:30 AM
if they are the same as the o2 (which i would think it is) then the car in my back yard has it
Primer Counts as Custom Paint Right?
BTW: This is my Sig.
Sunday, January 11, 2009 6:20 AM
I found a plastic tank locally, but they told me that it will not work on a car with a steel tank since the harness is different. I thought the harness was the same???
Jason
99 Z24 Supercharged
157hp/171tq - NA
190hp/170tq @ 6psi
LD9 for Life
Sunday, January 11, 2009 9:38 AM
When i replaced my metal tank with the plastic i just used the plastic fuel pump and everything worked fine
Sunday, January 11, 2009 9:47 AM
i'm just buying a new metal tanks and painting it before i put it on then dropping a 96-98 sender unit with this pump into it and calling it a day
JBO since July 30, 2001
Saturday, February 14, 2009 9:57 AM
Mike do you still need that hose bud? I haven't looked at this thread in ages and I have 2 hoses... The one is still on my 99's tank and I have the new one on the plastic tank..
Sunday, February 15, 2009 5:34 AM
I've been doing this a long time. Have a fleet of vans with 300k+ miles in New England. Marine grease or oil will generally outlast most paints. Old fashioned tarpaper soaked in oil then placed between tank and strap prevents both tank and strap from rusting. Messy for a while, but no problem for street cars.
hth
-->Slow
Sunday, February 15, 2009 6:28 AM
since my car is summer only i'm just gonna use rubberized undercoating, i really gotta order this pump 1 of these days
Sunday, February 15, 2009 11:26 AM
how much lighter is the plastic one over the steel?
Needing 2.3 oil pump stuff? PM me...
