I have looked around on jbody.org, ecotecforum.com, ecotecpower.com, and cobaltss.net for info on this.
I have seen Cody@RDFABS write up about the LSJ injectors working in the 03-05 fuel rail on the L61, but my question is will these fit in my 02 L61 fuel rail, or should i switch to the 03-05 fuel rail?
Thanks for any help reguarding this matter and thanks ahead of time for any help!
CHAD
sorry to thread jack but. from reading that. i need to swap to an 02 fuel rail for a direct fit on my 03?
a few have been able to run LSJ injectors by pulling the spacers up in order to take up the distance.  it works, but.. not really a solution since the injectors aren't actually bedded firmly into something.
Thanks PJ!!!
Also do they just plug in or do i need the LSJ harness. Thanks again.
CHAD
plug and play, the only issue is the injector length.. but with the 02 rail, its a direct swap.
with the 03 you gotta mess with it a bit
Fastfire, you're right! I don't have the clips for the LSJ injectors. Can I use my stock ones?
"FRIENDS DON'T LET FRIENDS DRIVE STOCK"
and Spacers? Does the 02 ecotec fuel rail need spacers to fit the LSJ injectors? I have the injectors, with their rubber seals, that's it. Anything else I need to swap them? Spacers, anything?
The 02 fuel rail doesnt need spacers
219whp - I <3 whine
DaFlyinSkwir(LS61) /PJ/  OEM+ wrote:.. but with the 02 rail, its a direct swap.
make sure you get the hard fuel lines with the fuel rail. 03+ and 02 are not the same.
my carDomain updated 10/31/09 Forged and Supercharged
are the lsj injectors 42# injectors??? or is that the stage 1 or 2??? i have a link on here in anouther thread to some lsj 42#'ers are those stock or staged??? still direct fit on an 02 rail??? harness??
Lsj's are 36lb. The 42's i believe are the stage 1's but you can also get them through other places like zzp. I'm running the lsj's in my s/c'd ld9 and i love them.
Eat my shift
