Ok i read this;
http://www.j-body.org/faq//135/
I've got a 1998 2200 5-speed.
I'm getting a 96' automatic with a 2.4 in it(complete).
The first question is, can I use the 96' 2.4 in my 98' jbody?
Asides from the manual transmission what else do I need?
(adding to this.. since my cavalier is already a manual, the manual 2.4 tranny will bolt right up correct?)
"...you will also need the PCM out of a manual or just get your friends VIN number or someones that has a manual and take yours to dealership and they will reprogram it."
Can I take the 96' PCM with the cars VIN and get it reprogrammed for a manual?
Or do I need to get a new manual PCM?
<img src="http://www.majhost.com/gallery/HCAJosh/crap/shooshined.jpg">
- putting the pieces back together -
Yes you can use the 96 engine in your 98.
Yes the manual 2.4 tranny will bolt right up.
Now im not too sure on the pcm question you had.
You can have your PCM reflashed, since it is physically the same as a 2.4 PCM. Just have it reflashed to a 97-99, doesn't matter which year, just not a 96 since some 96's had different PCM's... Plus the 96's aren't flashable by HPT.
So my best option here would to get my current(2200) ecu reflashed for a 2.4?
"...you will also need the PCM out of a manual or just get your friends VIN number or someones that has a manual and take yours to dealership and they will reprogram it..."
Can I just write down a VIN# from a junkyard, or is there some law regarding using another cars VIN# for any use?
alrighty then.
all you really need the VIN for is to get a flash put on like they will use that vin so they can get the program for it, the files aren't list 2.4 5spd j body, i used EBAY for a VIN
JBO since July 30, 2001
Ok. One last question.. for now.
With the reflash, do I have to take the whole car or can I pull out the pcm and just take it?
Is your 2200 busted?
If not I may be interested in some of the parts or complete.
Is the auto tranny 4 speed?
Ok i have a question> first  sorry for jacking the thred Can a 1998 2.4manual fit in a 2001 2200 auto?
phil
yes and no lol not a direct fit but it will bolt up to the motor as the 2001 had a getrag and 98 had an isuzu
my kill list:a geo metro and a mac semi wow did i kill that thing
Ok the question is about the trans will it mount upwith out making mounts for it?cause i have a auto in my car now. is worth doing the swapp if i have everything?
thanks
phil
