I was looking around for springs that may possibly work for us ld9 guys. There isnt a lot out there but I find some that might be compatible. Here they are.
COMP Cams 26113
Part Number: CCA-26113-24
Number of Springs Per Valve: Single
Outside Diameter of Outer Spring (in): 1.061 in.
Coil Bind Height (in): 0.952 in.
Damper Spring Included: No
Spring Rate (lbs/in): 191 lbs./in.
Inside Diameter of Outer Spring (in): 0.738 in.
Valve Spring Style: Beehive
Coated: No
Notes: O.D. at top of spring is 0.959 in. and I.D. at top is 0.636 in.
Valve Springs, Single, 0.959 in. Outside Diameter, 191 lbs./in. Rate, 0.952 in. Coil Bind Height, Set of 24
Recommended Camshaft Style Roller hydraulic
Installed Height (in) 1.570 in.
Seat Pressure at Installed Height (lbs) 93 lbs.
Open Height (in) 1.020 in.
Open Pressure (lbs) 198 lbs.
Application Notes 1994-2000 4.6 Ford SOHC
COMP Cams 26123
Part Number: CCA-26123-1
Outside Diameter of Outer Spring (in): 1.105 in.
Coil Bind Height (in): 0.900 in.
Spring Rate (lbs/in): 324 lbs./in.
Inside Diameter of Outer Spring (in): 0.745 in.
Coated: No
Quantity: Sold individually.
Notes: O.D. at top of spring is 0.943 in. and I.D. at top is 0.580 in.
Valve Spring, Single, 1.105 in. Outside Diameter, 324 lbs./in. Rate, 0.900 in. Coil Bind Height, Each
Installed Height (in) 1.470 in.
Seat Pressure at Installed Height (lbs) 90 lbs.
Open Height (in) 0.970 in.
Open Pressure (lbs) 252 lbs.
Application Notes Designed to fit 4.6L DOHC engines.
Eibach 25409-116Brand:
Product Line: Eibach EVS Pro Valve Springs
Part Type: Valve Springs
Part Number: EIB-25409-116
Outside Diameter of Outer Spring (in): 1.040 in.
Coil Bind Height (in): 0.950 in.
Inside Diameter of Inner Spring (in): 0.740 in.
Valve Spring Style: Conical
Coated: No
Quantity: Sold as a set of 16.
Valve Springs, Single, 1.040 in. o.d.,.740 in. i.d.,202 lbs. Open Pressure,.950 in. Coil Bind Height,Set of 16
Seat Pressure at Installed Height (lbs) 84 lbs.
Open Pressure (lbs) 202 lbs.
cool.
the induction dynamics head used crower springs... if i could find the info pertaining to the ld9 and lg0 springs they can make us some.
Needing 2.3 oil pump stuff? PM me...
sorry i forgot the free lenght
26113 is Free Length: 2.200
I'll post the others if I can find them. The lenght seems a bit long so i guess i dont know if the comp cams would work.
eibach makes valve springs??? since when???
01' Z24 5 speed
422whp/400wtq
T4 Turbocharged
Built LD9
HP Tuners
since they got rick moranis to shrink some.
Thanks for the info! Does anyone have the stock LD9 spring #'s and the HO spring #'s for comparison? I am a valvetrain noob and I am looking for alternatives to HO springs.
To the OP, did you pick those springs out of the many Comp cam springs because those would work the best? Their whole catalog is
here.
Also would we be able to use the titanium retainers it lists for the springs?
PSN ID: Phatchance249
clyde a a a a a a a a a a a
Shawn McKenzie wrote:Thanks for the info! Does anyone have the stock LD9 spring #'s and the HO spring #'s for comparison? I am a valvetrain noob and I am looking for alternatives to HO springs.
To the OP, did you pick those springs out of the many Comp cam springs because those would work the best? Their whole catalog is here.
the reason i looked at these is becuase they have a similar install height, the bind height is lower and the seat pressure is higher. I have the manta parts springs and their install height is around 1.50 for intake and exhaust is 1.35, seat pressure is about 70 and the bind height is .980 so with the secrete cams that i have that dont leave much room for extra lift if I want to go with higher lift cams. Like I said these might be options for someone. If i decide to go with custom made cams I will use whatever springs they recomende i use. If I buy new cams and springs my secret cams and mantapart springs will be up for sale.
