2.3 cams and the 2.4 cam tower dilemma - Performance Forum
Thursday, February 26, 2009 4:55 PM
post was made about seeing if anyone could do this mod and the answer is "YES"
got my 2.3 ho's done for anyone interested in buying them and got the W41's modded as well for my car
2.4 CAM TOWER MODDED FOR THE 35MM LIFTER
2.3 HO CAM MODDED FOR THE PS PUMP AND THE OIL HOLE
Questions/comments/concerns, hope you boys enjoy, i know i do
Re: 2.3 cams and the 2.4 cam tower dilemma
Thursday, February 26, 2009 5:19 PM
How much did it cost you to have both the cam and tower done?
Thursday, February 26, 2009 5:26 PM
nice way to go. atleast you got it ready now. get it in
Thursday, February 26, 2009 5:27 PM
very nice. NOW i get where the oil hole goes....
did they cut the end of the cam down?
Needing 2.3 oil pump stuff? PM me...
Thursday, February 26, 2009 7:41 PM
I just used a chop saw on mine. Here are some pics of of when i did mine...
It was really easy and took about 30 min...
I also had to clearance my towers, even after it was modded for the 35mm lifters. Did anyone else have to do that as well?
Thursday, February 26, 2009 7:50 PM
^Where did you get the HEX insert?
"Never argue with an idiot. They'll drag you down to their level, then beat you with experience!" -Anonymous
Thursday, February 26, 2009 8:04 PM
Thursday, February 26, 2009 8:12 PM
I just did a complete 2.3 top swap, PS system and all.
My Cav
I give up...
Friday, February 27, 2009 7:41 AM
I can't wait to get mine done
Jason
99 Z24 Supercharged
157hp/171tq - NA
190hp/170tq @ 6psi
LG0/LD9 for Life
Friday, February 27, 2009 8:41 AM
Dale Young wrote:How much did it cost you to have both the cam and tower done?
messaged
Vincent Morris wrote:nice way to go. atleast you got it ready now. get it in
waiting for the head to show up
z yaaaa wrote:very nice. NOW i get where the oil hole goes....
yes they cut the cam down
jmarks82 wrote:I also had to clearance my towers, even after it was modded for the 35mm lifters. Did anyone else have to do that as well?
yeah jmarks, even after they made it work for the 35mm lifters they had to do a tiny bit more to make the lobes clear but was minor
Friday, February 27, 2009 10:30 AM
so what exactly is involved in getting the HO cams to work in the ld9 towers? and did you have the cam sensor pad machined???
01' Z24 5 speed
422whp/400wtq
T4 Turbocharged
Built LD9
HP Tuners
Friday, February 27, 2009 10:46 AM
bore LD9 lifter bores from 33mm to 35mm
cut end of cam off
drill hole for hex insert and press insert in end of cam
drill oil passage hole in cam so hex is oiled
basically thats the jist of it.
Friday, February 27, 2009 10:56 AM
Publikdstrbnce wrote:so what exactly is involved in getting the HO cams to work in the ld9 towers? and did you have the cam sensor pad machined???
Noone I know of outside of Todd Miller has done the work for the CPS pad. Most people have opted to remove the CPS code from the PCM with HPT. Todd is no longer doing the CPS pad on cams
Jason
99 Z24 Supercharged
157hp/171tq - NA
190hp/170tq @ 6psi
LG0/LD9 for Life
Friday, February 27, 2009 2:20 PM
Joshua Dearman wrote:^Where did you get the HEX insert?
I cut a stock cam up for mine. But you can get the from the dealer. I was lucky enough to pick up a todd miller cam , but my cam works just as well, with out the cps however. But hpt fixed any problem i had with the engine light. The car even gets 24 mpg in the city, un-tuned. I cant wait to run it at the track!!
Friday, February 27, 2009 3:30 PM
Cool stuff guys! Do you find you need to raise the rev limiter to take advantage of the powerband with these cams (I'm assuming everyone has HPT to deal with the CPS code)? If so, have you done anything about the oiling system?
15.3 @ 89.97mph - '01 SFGT
'98 Acura 1.6EL Sport 5M Y7/Y8 mini me
Friday, February 27, 2009 8:38 PM
Good s hit. Possible to use the 2.3 tower with 2.4 tower caps that maintain the stock 2.4 ps pump mounting points?
Blew it up, build numbers coming soon
Friday, February 27, 2009 9:37 PM
^^^ nope. already been tried. completely different ends.
Friday, February 27, 2009 11:53 PM
See JR, I wasn't lie'n when I told you it was easy.
There is a .....other way to "mod" the tower to work with HO spec cams....... But none of you would like it.
Chris
'02 Z-24 Supercharged
Saturday, February 28, 2009 12:44 AM
Z yaaaa, u saying they won't seal or what?
Saturday, February 28, 2009 5:29 AM
The won't seal because the ends are completely different. The 2.3 intake tower has provisions for a seal, but none for the power steering. N/A madness posted a picture over a year ago with both towers beside each other
Jason
99 Z24 Supercharged
157hp/171tq - NA
190hp/170tq @ 6psi
LG0/LD9 for Life
Saturday, February 28, 2009 5:56 AM
Found Pauls pic
2.3 intake left......2.4 on the right
Jason
99 Z24 Supercharged
157hp/171tq - NA
190hp/170tq @ 6psi
LG0/LD9 for Life
Saturday, February 28, 2009 12:20 PM
jason- wtf i looked around all morning for it.
Thursday, March 05, 2009 8:38 AM
z yaaaa wrote:jason- wtf i looked around all morning for it.
Yeah, it took me some time to find it too
My parts should be there Monday
Jason
99 Z24 Supercharged
157hp/171tq - NA
190hp/170tq @ 6psi
LG0/LD9 for Life
