Which batteries can be used for our cars - Performance Forum
Sunday, March 01, 2009 12:32 PM
I've read about a couple of them a long time ago, but I can't find the posts or numbers for the batteries.
Which batteries are smaller in dimension and can be used with our cars? Any negative effects of using a smaller battery?
Re: Which batteries can be used for our cars
Sunday, March 01, 2009 12:37 PM
I just installed a Braille B2015.
Trevor Mullins wrote:
kind of like a screwed up kids sing along
pete the anal monkey lived in my bum..............
best epiosode of barney ever lol
Sunday, March 01, 2009 1:30 PM
That's perfect. Any worries with having a smaller battery?
Sunday, March 01, 2009 1:45 PM
Nope, Braille says the B2015 is great for daily driven 4 cylinders. But due to other "projects" on the car, i wont be able to test it out until later this month.
I also am not running an aftermarket sound system so the only extra load on it it my airride.
Sunday, March 01, 2009 2:59 PM
Trunk mount is the only way to fly! lol
Sunday, March 01, 2009 4:05 PM
Or you could save a lot of money and buy a Deka battery over the Braille.
Sunday, March 01, 2009 4:53 PM
The Braille isnt that expensive.
Sunday, March 01, 2009 5:54 PM
ohvrolla wrote:Or you could save a lot of money and buy a Deka battery over the Braille.
Link to said battery?
Sunday, March 01, 2009 6:21 PM
Odysee 680
Sunday, March 01, 2009 7:18 PM
WHITECAVY wrote:Odysee 680
Anyone ever tell you your engine bay is teh sex??
Did I mention I drive a 2000 Lumina now?-----wigm-tuners.org member
Sunday, March 01, 2009 8:13 PM
^^^ only every day.
which battery is lightest... braille or odyssey?
Needing 2.3 oil pump stuff? PM me...
Sunday, March 01, 2009 8:21 PM
Mine is 15lbs, but they do come in heavier and lighter models.
Edited 1 time(s). Last edited Sunday, March 01, 2009 8:22 PM
Sunday, March 01, 2009 8:26 PM
sweet. my optima red top is like 22lbs iirc. and the yellow top in the trunk is even heavier.. at 31 i think.
Sunday, March 01, 2009 8:27 PM
I can probably get a discount on the odyssey batteries as I used to work for Enersys the company that makes them, get me a part number and I will see what I can do for you guys if interested.
Monday, March 02, 2009 2:35 AM
Brailles are rebadged Dekas, which for those who don't know are AGM sealed motorcyle/tractor batteries. You can find a cheaper equivalent battery at Walmart or any parts store. Big Crank ETX16 for $68.95 is another rebadged Deka right inline with the $150+ msrp Braille that Tinkles posted. The "ETX" is the giveaway to being a Deka.
You can google it also. I've seen forums where the Deka ETX14 (ETX line is what you would want to use in a car) was tested against the Braille B14115 with practically identical results. So pretty much go out and buy a motorcyle battery and do the SAE post conversion for well under a $100.
Monday, March 02, 2009 6:26 AM
974drfire- Thanks man.
Lol@Brad.
My battery weighs 12 lbs I think. *will double check*
Monday, March 02, 2009 6:56 AM
I've worked on many Deka batteries in my days and I will vouch for their quality, for the price I don't think you can beat them.
Monday, March 02, 2009 8:43 AM
what optima batteries u using zyaaaaa? number wise that is?
WiGM-Tuners member.
Monday, March 02, 2009 9:19 AM
um... the red top is the smaller cca output one. the yellow top is just whatever it is i guess??
joey- how much could you get one just like david's for me? david- could you have a looksie and see what your part number is and send it to joey?
12lbs is pretty g'damn light for a battery. i dont want one for my white car because its has power everything and a decent sized stereo. but.. for my black car, definitely. it doesnt have one power option and will not have a system so im not worried one bit.
Monday, March 02, 2009 9:24 AM
z yaaaa wrote:um... the red top is the smaller cca output one. the yellow top is just whatever it is i guess??
Then send me the price...
Monday, March 02, 2009 1:43 PM
If anyone is considering one of these batteries I would check for any parasitic drain with the car off. They don't like to come back to life after dying. Even something like a car alarm will pull a SLIGHT amount, which won't matter with a OEM spec'd battery, but could be detrimental with a Deka, Braille, or Odyssey. If you're big on drag racing or auto-x I can see using one of these when racing while using a OEM battery for daily driving. Or using two of the small ones in parallel and pulling one when it comes race time. A battery MAINTAINER wouldn't be a bad idea if used daily. Notice I said maintainer and not a trickle charger which doesn't know when to stop and can harm a battery.
Monday, March 02, 2009 4:22 PM
The 35/75 case is the model used as stock replacement, so anything that meets that will bolt in.
Go beyond the "bolt-on".
Monday, March 02, 2009 8:26 PM
Brad and Chris just give me the part # and I'll see what I can do for you guys, I don't know how much of a discount I get can get but it's worth a shot and could be a lot.
Tuesday, March 03, 2009 3:05 AM
z yaaaa wrote:sweet. my optima red top is like 22lbs iirc. and the yellow top in the trunk is even heavier.. at 31 i think.
Yellow top should be heavier. Deep cycle = thicker lead plates.
Tuesday, March 03, 2009 10:11 AM
ohvrolla wrote:If anyone is considering one of these batteries I would check for any parasitic drain with the car off. They don't like to come back to life after dying. Even something like a car alarm will pull a SLIGHT amount, which won't matter with a OEM spec'd battery, but could be detrimental with a Deka, Braille, or Odyssey. If you're big on drag racing or auto-x I can see using one of these when racing while using a OEM battery for daily driving. Or using two of the small ones in parallel and pulling one when it comes race time. A battery MAINTAINER wouldn't be a bad idea if used daily. Notice I said maintainer and not a trickle charger which doesn't know when to stop and can harm a battery.
Would any of these batteries have a problem with the car off and the radio on for a while?
