Guys its been a while since i posted in here but i finally got my walbro255 in and i thought that would be the end of my fuel woes. I was wrong, after 7 lbs of boost the air/fuel still goes lean . I have 36 lb brown tops in the car . Do i need to get a AFPR to bump up the fuel getting to the injectors because i still have the factory regulator on the rail?
  2.4 96 sunfire turbo
the problem skwirl is that i have a 96  and it wont run hptuners , i am in the process of getting a 97 ecu and putting that in and then running hp. Do you think that this along with bigger injectors and afpr would get the job done?
im hoping that this will solve said problem so
Built&Boosted moar
