okay well i got my header put on
and its currently only running on an open header
i ordered my high flow cat
and my magnaflow oval muffler (14832)
i need a resonator ?
its all 2.25 in diameter and i wanted to inlet/out let to be the same
i was look at cherry bombs 23'' glass pack will that kill my sound or be to big to fit between my cat and muffler?
i want a know throaty low deep sound.
if anyone can give me a link to a good resonator that has 2.25 inlet/outlet
thx
Cherry bomb sounds allright at first but degrades quickly soundwise compared to the Thrush glasspack Resonator which is almost as cheap, and straight through, perforated core for best flow. around $50..the thrush is available in a few sizes, I have the 28" which just barely fits...it looks exactly like the cherry bomb too, powdercoated red and sounds deep and low.
Don't buy from MANTAPART!!
There is no easy ways to get HP, no magic box or gizmo... And if you get more hp, there's no way to make your car still behave and sound like a stock one. More hp usually makes your car louder, more vibrations and harder to drive...but still people hope or think maby there's some magic way to have it all, comfort, stock sound and drive.
or you could spend the extra money and get a 22" long 4" round body Magnaflow resonator which will last you forever and will not degrade as quite as glasspacks.
4" is pretty tight under there in my car, the 3.5" is perfect
Scott Fry wrote:or you could spend the extra money and get a 22" long 4" round body Magnaflow resonator which will last you forever and will not degrade as quite as glasspacks.
Whats the p/n for the 22" long 4" round body magnaflow resonator?
Is it under muffers on magnaflow.com?
2005 LS Auto (Blue)
-M62 Kit with 3.1"
-ZZP S3 H/E setup
-Pacesetter armor coated header
-Magnaflow 22" resonator (p/n 10436)
-Vibrant CatBack
-TTR Upper and Lower motor mounts
