Is there a list of swappable parts from a ss/sc to the 03-05 eco?
Thats not a list, thats a gigantic blob of random posts and a expensive excuse to be different.
There is no list that I know of, but with the right amount of money and time every part can be swapped.
did, and didnt find anything. but thanks anyway for your input.
wow. nice way to help the poor guy.
there is no list.  but the only part that i can remember is the LSJ header and i think the supercharger can fit too
the head is. if you havent read the ecotec build book from gm id start there. there really isnt a list but you will def have to search to find some more things.
Borderlin3 wrote:Thats not a list, thats a gigantic blob of random posts and a expensive excuse to be different.
was going to help, till I read this.
have fun
Here's a list I've been compiling, by no means complete but maby 90% complete..
- LSJ Charger
- LSJ intake manifold
- Charger oil
-T/B o-ring #12575463 (a/c delco # 217-1592) same as cobalt ss
-manifold brace mounting bolts (x2) #11516342 (same as Cobalt SS )
-Intake Manifold Bracket Threw Bolt # 11515770 (same as Cobalt SS )
-Radiator inlet hose #22718761 (same as cobalt ss)
-Generator Relocation bracket # 12584365 (same as cobalt ss)
-relocation bracket bolts (x2) # 11518051 same as cobalt ss
-Relocation Bracket bolts (x2) # 11589134 ( same as cobalt ss )
-tensioner assmbley # 12583180 ( same as cobalt ss reuse stock tensioner bolt)
-Idler pulley bracket assembley #12584364 (same as cobalt ss )
-Idler pulley bracket bolts (X2) # 11518048 (same as cobalt ss)
-brake booster hose #10358940 (same as cobalt ss)
-Drive belt #12590815
-2 Bar MAP sensor
-GM or Custom tuned ECU (HP Tuners)
-intake tube
Anyone want to add to my list, there are complete lists out there, but I'm too lazy to find and post them..Borderlin3, if you are serious about doing this swap, you will find the info.
Don't buy from MANTAPART!!
There is no easy ways to get HP, no magic box or gizmo...  And if you get more hp, there's no way to make your car still behave and sound like a stock one.  More hp usually makes your car louder, more vibrations and harder to drive...but still people hope or think maby there's some magic way to have it all, comfort, stock sound and drive.
-Bosche (11k) Electric Water Pump?
-Gm green top 32lb injectors (or get larger injectors if you get a custom tune as the green are close to maxed out)
-supercharger bottom bracket
-Various gaskets needed
FastFireTwoTwo wrote:Here's a list I've been compiling, by no means complete but maby 90% complete..
-intake tube
you can't swap cobalt/redline ecu's into a jbody.
i haven't seen or heard the intake tube off an lsj workin either. i have the stock lsj intake setup in my garage but haven't had time to mock it up to see if the hole lines up w/ the way the intake pipe bends.
____________________________________________________________________________
my carDomain updated 3/13/09 Forged by B-day!
there is not a whole lot that can be swap from the ss/sc other than the s/c set up and the header, you can do a head swap from the ss/sc there are some post about it on here. also if ur after the s/c setup i made a complete part list of what u can get off the SS/SC.
s1lver_N1p wrote:FastFireTwoTwo wrote:Here's a list I've been compiling, by no means complete but maby 90% complete..
-intake tube
Yup, but you still need the ECU flashed by GM or Custom tuned which is why it's on the list.
FastFireTwoTwo wrote:s1lver_N1p wrote:FastFireTwoTwo wrote:Here's a list I've been compiling, by no means complete but maby 90% complete..
-intake tube
Borderlin3 wrote:Is there a list of swappable parts from a ss/sc to the 03-05 eco?
again the ecu is not swappable so it's not on his list. his ecu he has is what he needs to use.
