Hey all, just figured I would contribute a small list of parts that I've compiled that can be had through any NAPA store in the US. This is not a NAPA endorsement, I just work there so it was easy for me to list NAPA part #''s over anyone elses. Some are reflected upon in the MAnufacturer number but most as said, are just NAPA numbers, you can walk into any napa and get these parts without issue.
Onward...
First of all, for those of us boosting...What the hell are you doing trying to track down a (what year was it again>?) Camaro IAT sensor? (3/8NPT Threaded IAT)
Just ask for TS4052. It is the SAME sensor that is used for our Coolant temp sensor. Not a damn bit of difference either way. So any third gen cav CTS will be the part your after.
Threaded IAT Sensor: ECHLIN TS4052
Threaded IAT Sensor - Economy Brand: Mileage Plus TS4052SB
For those of us who know the value of an oil analysis...
NAPA oil analysis kit: FIL 4077
One step colder plugs....These are a BITCH to do for ACDelco's, IF anyone has any other information I've actually checked these with a micrometer (Measuring the depth of the ceramic) so I'm pretty sure these are all the ones you want.
OF course these are ACDelco's numbers so they are pretty universal.
LN2 LD9 L61
Stock: 41-948 41-963 41-105
-1 Step: 41-913 41-979 N/A - Eco Guys? Elaborate? Peej what are you running?
Brakes and Chassis stuff, but mainly brakes...
LONGER WHEEL STUDS! These are important, far too overlooked with all the aftermarket wheels on here...this along with properly used centric rings should eliminate all possibility of you losing a wheel on the highway like vincent along with a few others have (Sorry vince, your just the most recent I rememeber seeing...) :-)
stock is 641-1621
Overlength (add's 15mm I think) plenty of meat here... is 641-1581
Neon Swap
Rear Pads (96 Neon)
Cheapies (@!#$): TS7438BM
Midgrade: SS7438BM
Premium Met: UP7438BM
Premium Ceramic: AD7438BM <<<Best pad for this application....For the most part will solve any noise issues that chrysler had alot of problems with. Great Pads and lifetime warranty.
Parking Brake shoes
UP643PB
Rotors
STD Premium: 4886551
STD Ultra Premium (Black zinc coating etc, nice rotors): 86551
Drilled and Slotted Premium: PR86551L left and PR86551R right
PArking Brake hardware: UP 2981
Calipers (Reman so you'll need cores...)
242-3066
242-3067
Caliper Bolts and slides: UP 82815W
How About an NWF Swap?
Malibu Bearings
Cheap: PBR930080
Good: BR930080
Ball Joints
Cheap: 104258
Good: 260-1490
Calipers (98 F-Body)
242-2258
242-2259
Rotors (01 Impala)
STD Premium: 4886641
STD Ultra Premium: 86641
Drilled and SLotted Ultra PRemium
PR86641L
PR86641R
Exhausts...
2.5" Exhaust,
4x9.5x14 Dynomax Super turbo (Straight Through) Alluminized Muffler: 17219
18" Glasspack: 24235
CAT: 15028
And for those of us with rocker arms...
Stock issue Exhaust gasket... with a 1.470" Exit
OR
a MS93812 with a 1.700" exit :-)
Thanks guys, again I dont mean this as an advertisement, I just see alot of "OH well ask for this part for this year make and model of car and with the way manufacturers change @!#$ nowadays....its better to have solid part numbers. Let me know if there is anything more you'd like me to check and or add and I can get it for you or if you feel like adding yourself you can get part numbers on napaonline or rockauto. Both of which are pretty easy to find and have good pictures and part numbers.
Thanks again! and I hope it helped some people!
wow!! definitely some good #'s in there im sure ill use one day.
thanks.
I'm tired of wasting my time... now I'm breakin' free.
just for kicks i crossed referenced all of the numbers on this list from the autozone inventory, because i work there, and they all are valid numbers in our system also and are easily accessible. Nice write up man!
someone should sticky this
