ok is it just me or does the cav gas gauge suck.
my gas gauge bobs around all over the place and i never know how much gas i have. i spent $75 in gas in 4 days because of this. i cant afford that. Now i know i am technically spending the same amount monthly but i cant spend it all that close together.
Please tell me if there is something i can do about this. i need this info as soon as possible.
The man who smiles when things go wrong has thought of someone to blame it on. - Robert Bloch
Assume you get 25 mpg, and go about 325 miles every time you fill up. Use your odometer.
i have been using the ODO but due to the different driving conditions i am constantly exposed to that is easier said than done.
is this a gauge problem or a pump problem? a friend told me if the float in the pump gets cracked or dryrotted this can happen. can i replace the float without replacing the entire pump?
anyone have any more in-depth info on this TSB
01-06-04-027: Revised Fuel Gauge Inaccurate or Inoperative Diagnostic Procedure;1999 Chevrolet Cavalier and Pontiac Sunfire. ENGINE/PROPULSION 6-01
Found this in the faq
