Does anyone know the part number for the NGK Iridium spark plugs for the 2200 LN2 motor? I am looking to buy them but can't seem to find the exact part number anywhere. The NGK Iridium spark plugs are the best spark plugs that NGK makes right? Also, will I see any extra power from them on a 2200 motor with a CAI and header-back exhaust? I've never replaced  the spark plugs on my car since I have owned the car, which has been almost 3 years, so I think that it is definitely time to do it. Any opinions or thoughts? Thanks in advance.
TR55IX is the part number for the iridium ix's in the 2200 and as far as i know they are the best plug for the money.
 IF YOUR GONNA GO DOWN ... THEN GO DOWN IN FLAMES
Ac delco run the best on a NA motor... you don't get power from spark plugs.  Upgrade the plug wires and coils/ignition and you'll get a little bit of extra throttle response and smoother acceleration, gas mileage.
Don't buy from MANTAPART!!
There is no easy ways to get HP, no magic box or gizmo...  And if you get more hp, there's no way to make your car still behave and sound like a stock one.  More hp usually makes your car louder, more vibrations and harder to drive...but still people hope or think maby there's some magic way to have it all, comfort, stock sound and drive.
Whats a good brand to upgrade the plugs and wires to?
FastFireTwoTwo wrote:Ac delco run the best on a NA motor... you don't get power from spark plugs.  Upgrade the plug wires and coils/ignition and you'll get a little bit of extra throttle response and smoother acceleration, gas mileage.
on a 2.2 eco, is it just the ignition coils you can upgrade?  are there wires to upgrade too?
Eco doesn't use wires but you can convert it to a coil and wire setup, there are threads on it here..  there's also plug and play upgrades such as aftermarket control modules and ignition boots...  again, you'd have to search on here...I think accel was one of the companies that made the plug and play...was never interested in that stuff, for the money it's much better spent elsewhere.
