Was looking at a 62mm throttle body from SMGmotoring, anyone have one? Just wondering if its money well spent or if it just sounds cool, and if I'll have to get it tuned or it will be able to compensate for the larger air volume on its own.....
i've got one. added it when i added the supercharger so i can't really give an opinion on stock vs SMG comparison. i don't think you'll need to get a retune. it may be helpful if you access to hpt and don't mind spendin the money.
____________________________________________________________________________
my carDomain updated 5/8/09 Goal to be forged by Labor Day!
GET IT! I have a non SMG but still 62mm. Feel a difference for sure! My 4th gear became my fastest gear instead of the third
"FRIENDS DON'T LET FRIENDS DRIVE STOCK"
So would the gains be even better on a boosted engine? rather then a N/A? Or is it like a 2hp gain for 200$ kinda thing?
SpeedyPip wrote:Was looking at a 62mm throttle body from SMGmotoring, anyone have one? Just wondering if its money well spent or if it just sounds cool, and if I'll have to get it tuned or it will be able to compensate for the larger air volume on its own.....
Although you will not need a tune persay, it's generally accepted that the stock injectors on the ecotec are maxxed on a stock set up, so any addiional flow @ high rpm will be taxing them even more. You can bolt on the TB and probably feel a gain, but with the stock injectors pushing a 90% duty cycle @ redline, its not an ideal situation. To get the most out of it (read as - to do it right), you'll need at least 30lb/hr injectors and a tune.
Oldskool, My next question is...is smg's website they have eco injectors that offer a 10% flow increase over stock, would those be sufficient or should I look for something different?
OEM, let know when they are done and pics and a price would be great, thanks!
oldskool wrote:SpeedyPip wrote:Was looking at a 62mm throttle body from SMGmotoring, anyone have one? Just wondering if its money well spent or if it just sounds cool, and if I'll have to get it tuned or it will be able to compensate for the larger air volume on its own.....
am thinking the 62mm throttle body AND a cobalt ss/sc manifold. if the ones Speedy is referring to aren't sufficient, what injectors are recommended and where do you get them?
Ummm i hope you know that you need the M62 to use the Cobalt SS/SC intake manifold.
Tinkles
2003 Cavalier 1SV
Bagged and Blown
I think he is referring to the 2.4 eco manifold.
Im quite curious about the throttle body also.
13.520 @ 98mph! 220whp 234tq
Instead of a custom tune, would the gm reflash with the sc kit injectors be okay?
SpeedyPip wrote:Oldskool, My next question is...is smg's website they have eco injectors that offer a 10% flow increase over stock, would those be sufficient or should I look for something different?
10% extra flow doesn't give you any room at all to grow. I cannot speak for the sc intake mani, but with the 2.4 LE5 mani, revving to 7k lets you take advantage of your new powerband, but also increases your IDC even further. I was pushing 90% on the stock injectors on the stock redline...
I got my ford red tops on ebay for 75 shipped. they are 30lbs/hr, whereas stock are 24 lbs/hr.
Tinkles wrote:Ummm i hope you know that you need the M62 to use the Cobalt SS/SC intake manifold.
no i was referring to a regular ss cobalt, my bad. i believe i read somewhere it makes somewhat of a difference.
02cavcruzin wrote:I think he is referring to the 2.4 eco manifold.
didn't know you could do that, any gains?
No offense, but i would do more research on the swap.
Tinkles
2003 Cavalier 1SV
Bagged and Blown
i'd like to hear more on the tb's. i want one!!! lol
horsepower is the force that determines at what speed you hit the wall, torque is the force that determines how far you take the wall with you after you hit it.
Tinkles wrote:No offense, but i would do more research on the swap.
none taken. i am always reading up, never hurts to ask though.. somebody has to be dumb and somebody has to be smart in order for forums to work :-)
any word on these tb's?
I have the 62mm TB from SMG..I cant say the differance was huge but makes a nice whistling noise at certain RPMs...And just get the 2.4 intake set up,And use the green top injectors from a cobalt SS Supercharged,You can find these used on cobalt SS forms..They are plug and play and work well..with the bigger injectors you will need a tune...but If you are doing the 2.4 intake get a tue anyways to get some gains out of it..But you can bolt on the TB with no tuning once again you will only pick up small gains..The GM computer is a very crapy factory tune...Just because the car is suppost to be nothing more than a granny car..
The 62MM tb is a very nice mod to do, NA or boosted
Where on here can I find more info on the 2.4 intake set up? Like list of parts and how to do it? Any help is great, thanks for all the replys guys
