befor you say SEARCH, i have, i bought an LD2 to put in my 95 sunfire gt, first question is does it have balancing shafts? second, if they make it were can i get a delete kit? third if its simple does someone have a write up saved they can just post it? last, how much vibration am i going to have with removing... thanks
first- if you bought an 'LD2' you'd better make sure its the 95 2.3, because if its any other year your going to need to modify things to get it to work.  if you got a 95 2.3 then to answer your question about the balance shafts-yes, just like the 2.4, it does.
and no, no known 'delete' kits exist. just a good old (non 95) 2.3 oil pump swap is all we got. j body performance suposidly made balance shaft BLANKS but these dont delete them and good luck getting ahold of jbp.
vibration? only the 95-02 gm panzy ass gm engineers could feel a difference in vibration between these engines.
PFFT secret cams?! pm me if you want a real upgrade.
the fellow i bought it from said it was out of a 89 or 90 skylark, does that mean im balance shaft free?
Try jbodyperformance.com for your balance shaft BLANKS. Thats where I got mine for the ld9. They might have them for the 2.3.
^^^ when the hell did you get em though, jay?
thanks for that, i will be in contact with them
Brad I got them like two years ago.
I'd like to see the difference in performance between the 2.3 conversion and the balance delete.
thats right. two years ago. when they actually were in business.
try to contact them though...
I didn't realize they went out of business.. Wouldnt they have shut down their web site though?
