a girl that has started racing is running a 95 cavalier and is having problems running way lean, is there an easy way to add on an FPR or any way to flo more fuel to the injectors, it has a fuel cell with a 60+ psi pump
the plugs are ghost white from running so lean
Accel makes an adjustable fuel pressure regulator that fits right into the fuel rail. Their fuel rail is similar if not identical to the 2.4 engine so the afpr should be the same.
Here's is the page for the one I'm talking about.
This is what I'm using and works great.
Good luck.
Misnblu.com
Newbie member since 1999
Thank you Dave and JBO!
