do you have to get a new distributor cap coils...?
what is it for a car, motor, year?
yeah you have to throw some info our way.  we are not mind readers
oh yeah sorry, 2005 cavalier, 2.2L ecotec.
Make sure you change the flux capacitor.
Tinkles
2003 Cavalier 1SV
Bagged and Blown
ohc is not me, wait for the next reader haha
Jesse Kiesow wrote:oh yeah sorry, 2005 cavalier, 2.2L ecotec.
lol.  not trying to be an ass,  but go pop your hood and tell me where you see plug wires or a distributor cap
I'm not quite sure if we're on the same page but i want to know what would have to go with some aftermarket wires and plugs...
sorry new to moding... goin off of things i've heard I need, seemed kind of weird...
maybe you should do some research yourself into what you need instead of listening to people have no clue
Have you done anything else to the car yet? Your profile doesn't have the car registered...
2010 Honda Fit LX
yeah, i got a AEM cold air intake system and a muffler so far, not much but trying to find the best ways to make it better.
You'll get more of a gain out of a header and full exhaust than "upgrading" the ignition in an eco.
Tinkles
2003 Cavalier 1SV
Bagged and Blown
Basically, they're ALL trying to say:
1. OPEN your friggin hood.
2. LOOK at everything under there.
3. STOP! Don't "mod" anything else in there, UNLESS you can identify the point of and the name of 90% of the stuff IN there. Good! Now...
4. STOP! Don't "mod" anything else in there, UNLESS you have read
this.
5. NOW, you can post an intelligent question here on our lovely JBO.
ecotecs in the cavcs dont have plug wires or caps etc. only thing ot do is plugs and rksport ocil spring inserts
DJ Beefy wrote:ecotecs in the cavcs dont have plug wires or caps etc. only thing ot do is plugs and rksport ocil spring inserts
funny story i told a guy that his springs were bad and it was causing his misfire and he told be that i was a retard because an engine miss had nothing to do with his suspension
^one of my worst multiple typo's ever. lol o well. anyways yea, coil inserts, plugs thats it, unless you want to spend way too much on the msd setup.
pick up 20 feet of 4 guage wire and 14 copper connectors and ground off under your hood seperated by a gasket and right side strut mount  and finish off with one ending by the ecu ul gain about 4 hp if done right and ul feel this pick up a dremel and atttack ur tb, low temp thermostats with watter wetter and 30/70 ratio water to coolant and fan control 14x6 aloys rims on the front with spring clamps (sounds stupid but it works) e3 plugs or bosch fusium +4 ( people knock em but they work) upgrade to a 3' full exhaust with high flow cat  aswell 3" or bigger k&n cai and remove everything u dont need in the car thats excess weight run highest grade fuel u can premium is usually only 20 dollars more a full tank and dont cheap on oil start with this then save money and open the block
95gtzspec2 wrote:pick up 20 feet of 4 guage wire and 14 copper connectors and ground off under your hood seperated by a gasket and right side strut mount  and finish off with one ending by the ecu ul gain about 4 hp if done right and ul feel this pick up a dremel and atttack ur tb, low temp thermostats with watter wetter and 30/70 ratio water to coolant and fan control 14x6 aloys rims on the front with spring clamps (sounds stupid but it works) e3 plugs or bosch fusium +4 ( people knock em but they work) upgrade to a 3' full exhaust with high flow cat  aswell 3" or bigger k&n cai and remove everything u dont need in the car thats excess weight run highest grade fuel u can premium is usually only 20 dollars more a full tank and dont cheap on oil start with this then save money and open the block
Can someone translate this to english?
2010 Honda Fit LX
people on jbo your all gonna have to excuse me as i am not a well educated man i just know how to turn wrenchs so im sorry if what im posting is hard to read or not understandable but u have to look at it like this im from saskachewan canada i live in a town with 100 people or so and i droped out of school at around gr9 to work on cars so if my grammer and writeing is all faked up i apologize
if it start the next day it can be driven harder
