What does the egr path in my ecotec 202 do?
it looks blocked off. however is the cap make it wide open or closed up tight .
I need my egr block off plate and path to not be their because thats how the rsm charger runs.
anyone have any ideas about what to do?
horsepower is how hard you hit the wall, Torque is how far you push the wall with you
It doesn't do jack, that is just a block-off plate. Chop it off, and be damn careful cause of heat, then have a DAMN good welder weld the exhaust side (again, be VERY careful cause of heat), or just make a new block off plate.
does the intake side do anything? I don't want a vac leak.
