For this swap, what all would be needed? Engine, trNny, computer.... Anything else? And is there anything I would have to custom make? And do the mounts line up?
And wire harness. Mounts are the same.
How would I wire it up? And what to? And is there Any splicing or cutting wires involved?
you should be able to swap the engine harness and ecu right in place of the ones in your car....should just plug up to your plug in the firewall.  the top engine mount is different than the 2.2. the trans should bolt right in place of the 2.2 tranny.
So I need the 2.4 upper mount?
Yes that should be the only mount that is different. do you have the 3spd or 4spd auto tranny in your car right now?  if you have the 3pd auto you may need trans mounts too since the 2.4 only came with 4spd autos.
Yes unfortunatly I have 3 speed. So upper mount, motor, harness, computer, transmission, and cluster.
