I race a stock ecotec.  Must stay naturally aspirated.  I am changing to comp cams stage one cams and 2.4 intake.  What else should i do?  If i do decide to raise compression and head work who can tune this for me?  I live in southern Indiana.
Header, full exhaust, HPTuners.
no competant tuner will (street) tune it for you without a wideband and larger injectors if you don't already have them - at least 30lb/hr.
I am sorry i am new but what is wideband? and what brand injectors do you recommend.  After getting this who would tune.  Will never be street driven.
A wideband oxygen sensor is a sensor that can display air to fuel ratio with more resolution than a narroband oxygen sensor, with is mainly used for maintaining 14.7:1 AFR.
Ford red tops are a minimum - you can probably find them on ebay. under that or bosch red tops.  you'll need ford injector clips.
you have to find someone local with HPT, either another member or a dyno shop
bout
tree
fiddy
Hahn Stage II - Mitsu TD06-20g |3" Turbo-back Exhaust | 61mm Bored TB |
HP Tuners | Innovate WB02 | Spec Stage 3 | Team Green LSD | TurboTech Upper | Full Addco Sways | Sportlines & Yellows |
Pacesetter LSJ header
Full 2.5" exhaust
With the cams, full exhaust, 2.4 intake mani, and an aftermarket intake, you could make some decent power over stock.
Up the compression to 11.5:1 or 12:1 with custom pistons and Eagle H-Beams.. 200whp maybe?
LMFAO!!!!! blackeco... wow...
He said...........about tree fiddy!?!? I said, "TREE FIDDY!!! " ...then i knew it was that damn locness monstah!!!
lolo...but that 14.7:1 ratio is only for closed map
...I am the BEST at what I do...
"I guess your right[BlueBoost]. Me and my slow car are failers."
I say do head work and stage 2s trust me I saw a huge gain with just cams and valve springs car screams.
I installed comp cams and 2.4 intake and did not notice mush gains.  How is the easiest way to tune?
Well if you have stage ones that's why and if your untuned that's another problem. My buddies car with stage 1 feels stock you get in mine and the car screams all the way to redline.
