I am going to be installing a fuel pressure gauge in my car. Does anyone know what fitting I can use to hook it up to the fuel line. I don't really want to tap the fuel rail if I don't have to. I saw on jeggs they have some different fittings and want to know what size I might need.
If you've got the 2.4, you can cut your main fuel line at the hose end of it, add a barb to barg to 1/8inch NPT fitting adaptor to your cut lines and clamp down.
Then you can mount that sending unit onto your fuel line with no worries.
This is basically how I did my underhood fuel pressure gauge and has worked flawlessly for years.
It's the only way I know of to hook up your electric fuel pressure gauge without cutting your hard lines or tapping your fuel rail.
Good luck with it.
Misnblu.com
Newbie member since 1999
Thank you Dave and JBO!
awesome thank you that is what I will do.
