ok, bought a set of stage one cams, i kno i gotta upgrade the valve springs, but im wondering what else needs to be done. heard of machining the seats, just curious how much needs to be removed, and also what springs work. not looking for cheap, want it done right.
14.04 @ 101 ALLMOTOR
i know valve springs, seats shouldn't be an issue, you will need bigger injectors and tuning
LE61T PTE6262 Powered
@!#$, i need to order my Supertechs so we can finally find out if the retainers change the install height.
Qwibby {T3H Old QBE} wrote:i know valve springs, seats shouldn't be an issue, you will need bigger injectors and tuning
This.
Tinkles
2003 Cavalier 1SV
Bagged and Blown
everything not related to the cams working properly is takin care of. only thing im mainly concerned with is the right springs to buy and if maching seats its needed.
Comp Tech Line (these guys are good) 1 800 999 0853
Just ask them about coil bind / valve float and see what they say. I'm pretty sure they've tested this stuff...
http://www.compcams.com/Cam_Specs/CamDetails.aspx?csid=1080&sb=2
The only recommended part they list is break in lube... Not really helpful..
11.92 @ 122.69 MPH Rotrex Blower / Intercooled / Water-Meth / 100% Daily Driver / 381 WHP
