This is soo annoying.
I'm running MS-II with Dis coils, and the @!#$ wire kit I have sucks.
The straight boots are like bendy rubber and take like 5 mins per spark plug to seat properly.
I want something like a miata plug boot. Solid plastic.
But I can't find a wire kit,
MSD tech said they dont sell a solid style plug boot.
Mentioned a hemi style boot, but that was shotty and expensive as @!#$.
What are you guys using for plug boots?
take a plug boot with you to a parts store. see if the boots on the miata set are long enough. or even a neon. or civic. pretty much any car with single or dual overhead cams that runs plug wires. THEN, get an msd universal v8 8.8mm wire kit, comes with a spool of wire, you make your own lengths. use the boots from the wire set you bought at the store, and poof, you've got enough wire to make two sets, and now dont have to worry about junky wires.
I ended up using a set of ACCEL wires for an Acura application.
Bill Hahn Jr.
Hahn RaceCraft
World's Quickest and Fastest Street J-Bodies
Turbocharging GM FWD's since 1988
www.turbosystem.com
