like the title says, whats the point of the beam thats bolted to only one end of the subframe in the back and runs to the front, but doesnt even touch. and If I tighten up the sub frame can I get rid of it?
boobs now with Riboflabin"
Your removing your transmission arnt you..
I would not advise removing it. If anything, box it out.
It's called a pussy brace! At least that is what we call it. Keeps you from hitting your motor on crap.
i went almost a year without that brace(bent the orig. when i put the car into a curb @ 45mph)  in the cavi when i had it .    i think its to keep the subframe from shifting or its just one of GM's useless ideas for extra BS on a car
ShowOff Customz
03 Cavalier
73 Beetle
68 Fairlane 500
Joker -- Now Beretta Pimpin wrote:bent the orig. when i put the car into a curb @ 45mph)  in the cavi when i had it .    its just one of GM's useless ideas for extra BS on a car
hmmmm im glad i fail less than you. please re read what you just said ^  may want to combine it with
John Higgins wrote:It's called a pussy brace! At least that is what we call it. Keeps you from hitting your motor on crap.
good days sirs.
ur point sir ?
ShowOff Customz
03 Cavalier
73 Beetle
68 Fairlane 500
Joker -- Now Beretta Pimpin wrote:ur point sir ?
my point being, that useless bent piece of idea from gm saved ur motor. maybe not so usless
I figured as much. thanks for the help guys
gmanz24 (The Bash Whore) wrote:Joker -- Now Beretta Pimpin wrote:ur point sir ?
its funny cause its true its not life or death with out it but it help tie everything together almost every other gm car now have a full cradle not a half cradle which strengthens the front end and helps improve front crash test ratings if the cavalier had a full cradle it would have been way better in front crashes.
GM should make them the the us 3800 guys are making them in a front crash our cars will fold up before the subframe breaksthe car will be in a ball but the engine will be intact
JBO since July 30, 2001
