Installing MD's lightweight alternator pulley, and I need to know what size the tensioner pulley bolt is, and then according to the haynes manual I am assuming, you rotate the bolt, the tensioner moves, and you can just slip the belt off the alternator?
Yea getting any pulley off is a pain. You can install my RK sport crank pulley for sale at the same time.
lol. Good luck
-MD- LD9 wrote:T-55 or T-50 torx bit, and an open ended or closed ended wrench works fine for me.
Leave the alternator on the motor or take it off. Its up to you.
HHR alternator....
-MD- LD9 wrote:Most used an impact, and took the alternator off the motor. Some used a T-55 Torx socket, and a 15/16" open end wrench...Not 100% sure on wrench size.
Added....The later is what I used, but was a PAIN in the ass to get the nut off that held on the pulley.
Some aftermarket alternators have different size nuts. Some are metric,and some are standard.
Most are T-55 Torx. Some odd balls are T-50 Torx.
Most nuts are 15/16", but some are metric. I really need to make a list of all the possible sizes they are, but have never found the time.
The easiest way to change the pulley is to remove the alternator from the car.
