ok guys..decision to make...of course i already have head studs...but are MAIN studs really necassary ? not really concerned about the price just the availability, id like to put my shortblock together as soon as possible and main BOLTS are much cheaper and i can pick them up here in town. what benefits are really there for using the studs? im just kinda torn.
i used bolts last time on the stroker and didnt have an issue with them....should i hold off on the studs ? or not bother... t
thanks guys
My first build I did not have the ARP main studs, then I blew the HG and went with the ARP mains the second time around. I'd say do it just because the engine is apart. But not necessary if your not boostin I don't think.
jeez... you've done everything else. why stop now?
Stand in the corner and SCREAM with me!!!!
scott (section8cav) wrote:ok guys..decision to make...of course i already have head studs...but are MAIN studs really necassary ? not really concerned about the price just the availability, id like to put my shortblock together as soon as possible and main BOLTS are much cheaper and i can pick them up here in town. what benefits are really there for using the studs? im just kinda torn.
thanks guys
Studs primary reason of existance is they let you grab ALL available threads in the bore rather than until the head touches the part like with bolts. This generally means studs grab a few more threads since the bolts have to come up shy some, they can't risk having the bolts hit the bottom of the hole rather than tighten down the piece. With that in mind, studs have one more thing in their bag-o-tricks. They allow you to have a finer thread on the nut side which does require more torque to set due to the thread style however this does make the 'tighness' of the bind better and reduces changes of loosening, however remote, but still.
If you need neither of those, then you don't need studs.
Edited 1 time(s). Last edited Sunday, November 29, 2009 8:05 PM
"Never argue with an idiot. They'll drag you down to their level, then beat you with experience!" -Anonymous
z yaaaa wrote:jeez... you've done everything else. why stop now?
because i ordered studs 20 days ago...and they still arnt even shipped...the whole build is waiting on those stupid studs..OR i can just go to the dealer and buy bolts and put the short block together tomorrow........see my problem?
Dam scotty where did you get them from?
GMR has got nothing on this
scott (section8cav) wrote:z yaaaa wrote:jeez... you've done everything else. why stop now?
no, i dont see the problem. are you wanting the car back on the road IMMEDIATELY or something? LOL
whats the rush?
my goal is to have the engine and tranny IN the car by new year...im not gonna let this build take a year like it did last time...
Do you already have the mains machined? Personally,I use what ever fasteners I'm going to be using for the build at the time of machining to avoid warping/distorting machined surfaces from different torque specs.
That being said,I have a set of studs in one of my old blocks that I could pull and send you if you want to send me yours when they come in...
"The FACTS are always subject to CHANGE once the TRUTH is applied"
"In the entire history of man the only stupid questions are the ones that don't get asked"
come on scott, i know deadlines are a good thing but a few extra weeks isnt going to be a big deal, man!
weeks can turn into months..and im not letting that happen...it took me a YEAR to build this thing the first time...im not going without my car that long this time around.
i already canceled my order and reordered them from summit racing...was cheaper and they will be here tomorrow
problem solved
Why didn't you just get them from Karo
1999 Grand AM SE (Beater Car)
1997 GMC Sierra
2007 Honda CBR 600RR
2005 Honda TRX450R
i tried ...seemed karo was having trouble with my card...that and it being holidays probably slowed things down...where as summit got it out same day..theyve already arrived and currently being installed
