Hey im upgrading from my 42.5 # (440cc) to a 63 # (650cc) and just wondered if these were the correct ones that will fit the rail and plug into the harness on the 04 cav. thanks
http://www.racetronix.biz/itemdesc.asp?ic=FI114191&eq=&Tp=
Edited 2 time(s). Last edited Saturday, January 16, 2010 11:00 AM
Those fit in rail with no issue but cant remeber if they worked with my stock harness or another harness i had from a new cobalt.
Ricardo Rosario wrote:Those fit in rail with no issue but cant remember if they worked with my stock harness or another harness i had from a new cobalt.
i saw you replied and was like SWEET. but damn you lol. i got a month or so to get them worked out but i want to get them now and take them down when i take the car down so they are there. jason thinks these are the ones he has. not not 100% sure.
I would think they would work fine but not sure if the stock harness will plug right in or not.. I think the o-rings are 14mm diameter and that is what you need.. I would measure to see how long your 440s are and call them and see how long these injectors are..
vince are your 440s direct plug and play?
my 440cc are i believe, i would have to check them with the stock harness i have here as well but when i bought them, they came with a harness so im not positive its the stock harness. ill compare it to my stock harness i still have and let you know. but they fit the head just fine with no issues at all. they will for sure be for sale probably in a month or so once my car gets done. and tuned with the 650's just need to make sure the connector is right on these injectors first.
Actually your right jason does have those but he used my spare harness from a cobalt. But if your 440s are bosch style you can just order those injectors with the bosch clips. But length wise there good.
How do I order them with the Bosch style? I don't see an option on there on the site.
are you going to sell your smaller injector setup?
15.0 @ 90mph with only a intake and exhaust.
yes they are for sale but not until i get the car down there and the new ones in and semi tuned.
let me know when and price when this happens because I am looking for some.
Jason Brantner wrote:let me know when and price when this happens because I am looking for some.
should be soon. within a month. these are in my 04 with no problems at all. i just need to find the correct 650's
Coorect look at your 440s then look at the ev1 style to see if you have same connectors
Ricardo Rosario wrote:Coorect look at your 440s then look at the ev1 style to see if you have same connectors
yeah thats the plan. ill also check the connectors on the stock injectors i have too and see how they match up also. good idea.
