help with performance upgrades - Performance Forum
i have a 2004 cavalier, 2.2. ecotec. i already have a weapon-r wai, pacesetter header, magnaflow high flow cat, and full 2.5 inch custom exhaust w/ 29 inch resonator i got in anticipation for a turbo install after i go to/return from iraq. i have the 2.4 ecotec intake manifold w/ adapter plate, 62 mm throttle body, and compcams 113200 stage 1 n/a cams waiting to be installed, and i am trying to find out what i can do to get the best performance out of all this. there is one place in the town i am stationed near that can dyno-tune the car for $100 per hour, which i do plan on using, but i don't think they have much experience with 4 bangers, since this is a hillbilly town. are there any other parts or upgrades i need to buy to get it running good since it is my daily driver? i am a diesel mechanic in the army, but this whole tuning stuff is still new to me. i read forums all the time, but there is always different info being throwout, so might as well hit up the guys who know ecotec cavys the best.
try motor mounts, tranny mounts/mount. other than that you've hit up most the bolt-on's. you could p+p the head. or move on to internals, but really your best friend with what you have done/ will do is a tune.
sweet. i forgot to mention i already installed the upper an lower engine mounts bout 6 months ago. so i guess its time to get the tranny mounts now. does a head port an polish really make a significant difference? i figured it wouldn't do much unless you are driving a high power beast.
You'll need better valve springs with those cams.
219whp - I <3 whine
is it necessary to upgrade the valve springs? i never rev past 5500 to 6000 rpm unless i mis a shift. if it is, which springs could i use at a reasonable price?
The stock valve springs cannot support the increased lift that aftermarket cams provide. Quite a few people have had good results with Supertech's 78lb valve springs and can be found at thmotorsports.com for a decent price.
219whp - I <3 whine
does anyone know if the HD valvesprings from mantapart.com would be suitable to use with the compcams 113200 stage 1 cams?
Get the Super Tech or Ferrea from www.TurboTechRacing.com
They will be better
-Aaron
well i am looking to spend less than 200 at most on valve springs. does anyone have experience with springs from mantaparts.com?
louis cobarruviaz wrote:well i am looking to spend less than 200 at most on valve springs. does anyone have experience with springs from mantaparts.com?
do a search for mantapart in this section. i assure you, you'll not buy from them.
if i order the super tech 78 lb. springs, would i need to get new retainers, or could i use the stock ones?
If you order the spring kit, they will come with the required retainers(yes you need them). What i referenced to you is the CHEAPEST set of quality springs i have seen.
219whp - I <3 whine
thank you. i just ordered them this morning. side question, what kind of gains can someone normally expect with wai, 62mm tb, 2.4 intake manifold, cams, valve springs, header, hi flow cat, and full 2.5 exhaust? i know it ain't gonna be super quick, but i am hoping for around 25-30 hp/torque gain after all this.
I'd image you could see what you are hoping for. It would also be a very good idea to pick up a set of stock LSJ injectors, because on a 100% eco they are close to being maxed out already. Search the classifieds on CobaltSS.net and you should be able to get some for cheap.
Do you know if the shop uses HPTuners?
219whp - I <3 whine
i don't know if they do or not. there's one place in town that mods/tunes hondas regularly and he can use the program he normally uses for them to street tune my car supposedly. or the one place in town that has a dyno can tune it, but they usually just mess with v-8's. i would probably have to travel to Tuscon or more than likely Phoenix just to get tuned with hptuners. would i be able to safely run the stock injectors for a few months?
I wouldnt and for how cheap Cobalt guys are selling them for, it is a very good idea.
219whp - I <3 whine
ok, thanks man. i'll look around for those injectors
ok, so i got stock lsj injectors with a harness to splice into mine. the guy i got them from is a trifecta tuner dealer who says he can tune 04 l61's which is pretty sweet, and he recommended i get a wideband o2 before i get it tuned. would i need to go buy one of the $200+ o2 sets with gauge and all, or could i get away with only getting the sensor itself? oh, and would there be any adverse effects if i installed the injectors before i got a tune, or can the ecu automatically adjust for them?
1st there is no splicing for the LSJ injectors, they plug right into the stock harness. Your stock ECU will not automatically adjust for them. Some people including myself have noticed the LSJ injectors are a tad shorter than the stock L61 injectors.
I ended up inserting 2 small washers under each plastic injector cup.
You dont need a gauge, but you will need the sensor and the module the $200 kits come with.
219whp - I <3 whine
i read they were kinda short also, good way to fix it though. and i guess i gotta buy the wideband o2 set then. so, how do i overcome whatever problems that might happen with installing the lsj injectors? get a fuel management system? wait til i'm bout to get tuned and install them immediately beforehand? fuel pressure regulator? sorry, air fuel ratios and fuel management are things i don't understand for nothin.
Get the car tuned right after installing them.
219whp - I <3 whine
can do. thanks for the advise.
