Where/how do you typically hook it up?
The sending unit has a threaded end.
Do I tap it into the fuel rail?
<img src="http://www.majhost.com/gallery/HCAJosh/crap/shooshined.jpg">
- putting the pieces back together -
Anyone?
hmmmm, not that you mention it, i dont remember seeing the valve under the hood on my 2.2
on f/rail unscrew cap on inlet for meter[schrader valve] .the adapter fitting has 1/8npt thread for guage or a 90degree fitting b4 guage. the other side goes on schrader valve.you'll have to remove the valve insert inside schrader valve with a normal valve removal tool for tires valve stem.your done
im guessing this is for the ld9?? if so im unsure i know how i did mine for the ecotec though..
yeah its for a LD9.
I'll take a picture of the sending unit.
Its a glowshift.
Just add an adapter in the fuel feed line that has a port for a 1/8" gauge.  Can get them on Jegs.com for like $10-20.  Here are a few different variations on jegs:
Hey!  Click here
Or here!
Or even this link!!
"You can only feed them semen for so long before their legs fall  off."
4an?
I would recommend the 2nd link because those ones are more sturdy.  AKA, not tapped in into the middle of the line.  Can thread them right into the fuel rail.
Good, thats the one I ordered.
crap they only have the 6an.
Can always try a different brand or check Summit
