i checked the dealer and part source for a a/c pulley, but could not find one they said that it's only for the 2.2L because it was an option for the 2.2L and all the 2.4L came with a/c. does anyone know if there is any place that makes or carriers an a/c delete for the 2.4L?
Yawn........
-MD- Enforcer wrote:LOL, found it.
-MD- Enforcer wrote:OH MY GOD!
SEARCH SOME.
-MD- LD9 wrote:
"No bypass Pulley".... belt size should be 345K5, but it doesn't fit use a 350K5 belt.  All belt manufacturers are different. You might need a longer size belt.
Also...
GM bypass pulley 2.4L p/n # 24574519
Just because...GM bypass pulley 2.3L p/n # 22533199
Hope that helps.  Also removing all your ac junk I mean lines, pump, condensers and all...... only weight in at 33 pounds. FYI.
I have run my 2.4 with the bypass pulley and just a belt.  I have had better luck with the bypass pulley, and stock belt.
