oldschool59 wrote:Further add to my post,those rocker nuts are tightened down a lot,studs mounted to high due to the thickness of the guide plate,machine shop never milled the head to compensate.That simple mistake is a red light to the rest of the job!!
Rich Smith wrote:Thanks for the replies...it is the stock camshaft.
The shop gave the long block back w/ out oil. So I put a little Lucas on top of the lifters and filled the pan w/ oil. Then I turned the motor over , on ignition, and no plugs, in spurts until it got to about 50# oil press.
I can tell that the other rockers seam to off to one side as well, so I guess I need to find out why?
Rich Smith wrote:ok they re-taped the head to accept the rockers from the small block. These rockers are 1.6 ratio not the stock 1.5 found in the ln2. These rockers would not work w/ the ln2 studs. So that's why we went w/ these rockers. As for why they are not roller rockers is because I wanted it to appear "stock" if some one were to look under the valve cover. The guide plates and hole were machined for clearance, if it was machined to much ...well that I don't know?
Rich Grayo Jr. wrote:Rich Smith wrote:ok they re-taped the head to accept the rockers from the small block. These rockers are 1.6 ratio not the stock 1.5 found in the ln2. These rockers would not work w/ the ln2 studs. So that's why we went w/ these rockers. As for why they are not roller rockers is because I wanted it to appear "stock" if some one were to look under the valve cover. The guide plates and hole were machined for clearance, if it was machined to much ...well that I don't know?
i have SBC stamped roller tipped rockers on my car. didnt have to tap anything. ARP makes proper studs with a 3/8 top and m10 bottom.sounds to me like you got burned BADLY by the machine shop.
Rich Smith wrote:among other things, could very well be.
Do you think the fact that they re-taped the holes and used new studs is my problem?
Quote:i wasn't ONLY saying that, but yes, i was saying it.
Or are you just saying I got ripped off?
I'm just interested in figuring out what "could" be my problem and "potential" ways of fixing this, so when I call the machine shop on Monday I have some Ideas to go with.
So far there are some good points made!!!
OHV notec wrote:Mr Smith, there have been a lot ofWe have a winner!replies here from people who appear to be talking out of their anal passages. I think the most important thing you can tell us is what the specs are on the valve springs, and give us close-ups of the guide plate slots with the pushrods installed.
Don't worry about the "guideplate thickness", those were stock on '95s so there's no worry about milling the head for them.
I'd suggest readjusting the rockers yourself, as the shop may have had them too tight or too loose.
Also, was your head decked much?
OHV notec wrote:Mr Smith, there have been a lot ofreplies here from people who appear to be talking out of their anal passages. I think the most important thing you can tell us is what the specs are on the valve springs, and give us close-ups of the guide plate slots with the pushrods installed.
oldschool59 wrote:Just tryin to help,didn't expect to get insulted from a small dicked no-it-all!!!!!!!There you go, presenting
OHV notec wrote:Wow, pull some new guideplates. They F'd those up!oldschool59 wrote:Just tryin to help,didn't expect to get insulted from a small dicked no-it-all!!!!!!!There you go, presentingas fact, once again. If you don't know something for sure, use the phrases "I think" or "I believe". It would suck to have someone destroy something or spend unnecessary money because they truly believed you on a wild guess.
Oh yeah, it's "know-it-all[/quote
Ohv notec
I never presented anything as a fact!I simply made a few suggestions. Not enough information was supplied to form a conclusion so I was simply giving out some ideas that the op could check.I asumed that someone that was getting involved in a hi-perf build that includes changing rocker arm geometry would be capable of checking basic things and maybe understanding what was happening.I was incorrect obviously.When the op asked "how to adjust valve lash I realize how little he knows,no dissrespect intended to the op.
What I did not appreciate was the insult and the condesending tone in the response directed at me.I have over 30 yrs experience in engine building and mechanics as a profesion so I do have a bit of knowledge.
I also will apologize to you for my insult as that was uncalled for.
Sorry to sludge up this thread .To the op get some new guideplates and please have someone knowledgeable with engines check over the job because I would question the workmanship of any shop that would let a head out of the door with that kind of mess!!!
oldschool59 wrote:Could have fooled me. The section quoted by Dimer above sounds an awful lot like a piece of information presented factually...OHV notec wrote:Wow, pull some new guideplates. They F'd those up!I never presented anything as a fact!I simply made a few suggestions. Not enough information was supplied to form a conclusion so I was simply giving out some ideas that the op could check.I asumed that someone that was getting involved in a hi-perf build that includes changing rocker arm geometry would be capable of checking basic things and maybe understanding what was happening.I was incorrect obviously.When the op asked "how to adjust valve lash I realize how little he knows,no dissrespect intended to the op.oldschool59 wrote:Just tryin to help,didn't expect to get insulted from a small dicked no-it-all!!!!!!!There you go, presentingas fact, once again. If you don't know something for sure, use the phrases "I think" or "I believe". It would suck to have someone destroy something or spend unnecessary money because they truly believed you on a wild guess.
