Ok for someone with general no mechanic exp at all just how hard is it to install a new stock fuel injector on a 2.4 ld9 am honestly scared but i dont have the money for some else to do it and i can only afford the 2 injectors that are bad and i need this car up and running asap being its my only car.... so some feedback asap would be much appreciated
O and what special tool would need...
It's really easy.
There is a way to suck all the gas back down to the tank but I can't remember right now.
Once the car has been sitting for a awhile(this gives a chance for most of the gas to return to the tank)
Unbolt the two bolts holding the fuel rail to the cam tower. This will obviously let your fuel rail loose.
Undo the injector clips
Some gas will start to come out after you pull the injectors, have a rag ready. It wont be much.
Pull one injector at a time out and replace it with a new one with new O rings.
Make sure you put a TINY bit of oil on the O rings to slide back in the head with ease.
Re-nstall clips
Re-install the 2 fuel rail bolts.
Once you make sure all the injectors are sealed PRIME the fuel pump to check for leaks at the rail. If no leaks occur then start the car to check for leaks. Good to have a buddy with you at this point.
Thx w.cavy ill get started ill let you know if i run to anymore difficultly
hey am sorry i failed to mention something..here's my injector delima..today i started my car, and it started to rumble quite oddly, I could rev it and it would just stumble but not die. So the check engine light comes on and now am convince that i have a problem and i also smell gas.. So i pop the hood an i notice that theres gas coming out of injector # 1 and # 4. So now at this should i replace the o-rings? or the injector its self because these injectors cost like 87.00 dollars a pop and if its just a o-ring replacement that would save a chunk of money...thx again
Well now that you mention it, try to replace your O rings first. Clear your check engine light,  Then check for leaks. What does the check engine light say, did u get it scanned? I have some 2000+ 2.4 injectors for sale. PM me. What year is your Z?
its a 98 and i didnt get it scanned because i didnt wanna damage it being its my only car i very paranoid about going the distants with it
Ok, my injectors wouldn't work with your 98 then.
Thxs for the offer dude ill go with the o-rings it just seems like it makes more sence cause its pumping gas its just that its leakin!
NP man, good luck
