well i went to the races today and the Pro-Four modifieds were racing. i noticed one of the cars had an LN2 in it so i went down and looked
he runs an esslinger ford 2.3 adjustable cam gear on his cavalier with the matching ford crank timing gear and tensioner built onto a backing plate for tension. this setup was sweet!!!
o ya and the riser on the vavle cover is for a complete rocker stud girdle that has been made. all the cam bearings have individual oil lines and he turn this 8200-8700 RPM every lap, has had it up to 9500 RPM
the engien is 14:1 compression runs on alcohol and has twin weber side draft carbs on a custom manifold with electronic ignition
HP you ask?????
284 WHP  HAHAHAHAHAHAHAHA i was blown away
^^ Interesting ... i notice this too
Awesome! thanks for the post
"In Oldskool we trust"
Rich Grayo Jr. wrote:why do #1 and 4 primaries look bigger than 2 &3?
I think its just looks like that because of how 2 and 3 dip down under 1 and 4. If you look at the very top of them, they look all the same.
Help support the JBO! CLICK HERE!
I think its just a trick of the light or something.  Depending on the angle I look at it they either look the same or look a little bigger.
Anyway, awesome setup, wonder what kind of $$$ it would take to duplicate...
Arrival Blue 04 LS Sport
Eco
Turbo
Megasquirt
'Nuff said
Now thats a LN2 I could live with, very neat setup for sure.
I <3 JGM
 I think bigfoot is blurry,
that's the problem. It's not the photographer's fault. Bigfoot is blurry. And that's extra
scary to me. There's a large, out-of-focus monster, roaming the countryside.
"Run! He's fuzzy!" "Get outta here!"
the owner said he has $9000 invested, keep in mind this motor is in a modified that has 10" wide hoosier slicks and only weighs 1900 lbs
284whp???  Was it punched out and/or stroked?  If not, that's an 8-valve engine making conservatively 320hp at the crank, which would be almost 150hp/liter.
I'm not necessarily calling BS, but that's a lot to swallow.  I guess anything's possible with that kind of work and cash though.  Nice find~
this would never be able to be reproduced in a J body without extensive engine bay widening...
it is bored .060 but that is it, max CI for the class is 144 or 2330 cc
Thanks for posting this.
Absolutely awesome. Bookmarked for future LN2-bashing threads lol.
If you meet him again, try to get him to register here. Having an LN2 on top of the N/A list would be hilarious.
oldskool wrote:284whp???  Was it punched out and/or stroked?  If not, that's an 8-valve engine making conservatively 320hp at the crank, which would be almost 150hp/liter.
Its also running alcohol on 14:1 compression.  The hp/liter ratios you're used to seeing are based on pump gas.  Big difference.  I'd also imagine that rig is using some kind of solid rocker conversion so the cam is a lot more wicked than anything we've seen before.  There are a lot of Honda race engines out there making well over 300+ whp on race gas so I don't see anything skewed enough to really doubt the claim.
Eco
Turbo
Megasquirt
'Nuff said
dyno proof?
All I want... is a little of the good life
JerseyJayLN2 (Scarab) wrote:oldskool wrote:284whp???  Was it punched out and/or stroked?  If not, that's an 8-valve engine making conservatively 320hp at the crank, which would be almost 150hp/liter.
  Are those hondas SOHC 8-valve models - like a D15 or something?  You can build a 300whp n/a K24/K20 that runs on pump gas if you want.
Like i said, i'm not totally doubting the claim, but think about it - over 320 n/a hp at the crank out of a 2.3L 8-valve engine. 14:1 static cr is like 50% more compression than stock.  Yes, That's a lot.  Yes it may have a wicked cam and some extravagent head work, but it just seems unreal.
Put it this way - all things equal - one point of extra CR gains 5-10% roughly.  so five points on the LN2 would gain ~50% for example.  Were talking nearly three times the factory output here - n/a?
I guess i just need to educate myself on true dedicated race engines, and realize that this thing doesn't live on the street.
oldskool wrote:JerseyJayLN2 (Scarab) wrote:oldskool wrote:284whp???  Was it punched out and/or stroked?  If not, that's an 8-valve engine making conservatively 320hp at the crank, which would be almost 150hp/liter.
my ln2 is 12:1 .450 hydraulic cam with a stock head custom intake with carb and distributor... i put down 204 WHP
Ok i'm not saying it's impossible - just hard to swallow.
Bob, do you have a dyno?
just think what that motor would be like with  lower compression and a turbo
i dont have a dyno, a local one sponsors my race car
we put down 167hp with a stock 91 motor shaved head cam ditributor and carb.... no porting and no header
^^^ im sorry i just dont see how doing a fuel and a timing conversion to a LESS efficient setup is going to net you over 50whp more than anyone else on here n/a with a OHV.
