Ive been searching for a few hours and  cant find a damn thing....
Here's the story....
Was cruising to a little car meet that goes on every Wed and Idk why but all of a sudden i start hearing this little chatter noise while i'm cruising down the highway, i get off the highway with my all my other buddies car. One of them tells me your motor sounds a little loud..... So  i turned right went under a bridge and I started hearing it myself, we got to where we were going and sure enough i have a very loud lifter tick lol....
So enough with the Dr. Suess Story time. I decided I'm just going to build a head. Ive already got my Secret cams waiting to go in. But I want to know if there's better valves ( I thought about 1mm oversized SS valves from car customs.net ), retainers,lifter guides, lifters, and etc. I planned on taking it up and getting a port and polish and 3 angle valve job and have them machine the head to fit the oversized valves if i go the route. I plan on doing a bottom end build and a turbo set up as well this winter. IM still learning stuff about the ld9 motor its still new to me lol. Also if anybody has an extra head or parts I could use let me know thanks. Thanks to all future insight and help.....
sorry to tell ya bud but that noise is more than likely rod knock.
  its just a fact of life with an LD9 and a stock oil pump.
as for your head questions, your headed in the right direction. you can get the valves from car customs. im sure he can get you the guides to but if not, turbo tech racing has them.
depends on how far you wanna go with the build. titanium retainers can be had if you want them.
as for a head, you have a pm.
Anything worth doing is worth over doing.
Yeah i was thinking rod knock possibly as well i didnt look at it to much in the parking lot bc i was so pissed off,, i drove it down the road to my shop and left it there until tomarrow morning to look at it......
What kind of oil pumps are out there as an upgrade?
As for the head where can i pick up these titanium retainers i want to go full out with this head....... thanks for the info
you can go Mellings or the preferred 2.3 oil swap if your not scared of a bit of work
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my ride." -Amen
Which melling part number is it? is the 2.3 a better way to go even though it requires more work? whats needs to be modded on the oil pan to fit a 2.3 oil pump?
the block needs to be drilled out, and other passages plugged... head over to quad4forums.com and look it their write up section.  you'll see a nice write up with pics...
you may also be able to search here for it as well.
i'd get a machine shop to do the work...
as for your head questions, i agree with Brad... however i'm still running stock guides without issue... as long as the valves aren't loose, you should be good.
here are my build specs
my ld9 build wrote:Engine:
HPTuned by Joe Rutledge of Tuning Concepts
Powder Coated Kandy Red: Block - intake manifold - cam towers - timing chain housing - lower motor mount bracket - MDld9 alt pully
Powder Coated Black With Prismatic Flake: Oil Pan - Timing Chain Cover
BLOCK
* .020 Overbore (between 10.5:1 - 11:1) Wiseco Forged Pistons
* Wiseco Rings
* Wiseco Wrist Pins (Rated up to 500 HP)
* Eagle Forged Rods (Balanced)
* Clevite 77 .25mm over Main Berrings
* Clevite 77 .25mm over Rod Berrings
* 2.3 Oil Pump Swap
* Removed Balance Shafts
* Miller Performance Modified Oil Pan
* Lightened and Balanced GM Reground Crankshaft
* Helicoil (to retrofit knock sensor)
* OBX Precision Power Underdrive Crankshaft Pully
* ARP Main Studs
HEAD
* Fully Ported and Polished
* Decked .020 to raise compression
* Car Customs 1mm Over-sized Stainless Valves
* HO Springs
* 2.3/2.4 Retainers (made for 2.3 springs & 2.4 valves)
* HO Lifters
* Crane Cams .430 lift 222 duration HO Intake Cam (modified by Miller Performance for the LD9)
* Crane Cams .430 lift 222 duration HO Exhaust Cam
* 2.4 Intake Cam Housing Modified by Miller Performance to accept the bigger lifters and the .430 lift cam
* ARP Head Studs
SPEC Stage 3 Six Puck Clutch
SPEC Stage 3 Pressure Plate
SPEC Stage 3 Throwout Bearing
GM Stock Head Gasket
K&N Airfilter
AC Delco RAPIDFIRE Spark Plugs
XACT Performance Spark Plug Boots
2.3 HO Painted IDI Cover
2.3 HO Intake Manifold
Fontana Phenolic Spacer
1995 LO 56mm Throttle-body (and i kept my cruise control)
RK Sport Lower Dog-bone Motor Mount
RK Sport Upper Motor Mount Insert
Car Customs Front and Rear Transmission Mounts
MD-LD9 Light Weight Alternator Pully
OBX Pacesetter Style Header
AEM Wideband O2 Sensor
2 1/4" pipe from header to cat
Magnaflow High Flow Catalytic Converter
Mobil 1 5W30 Synthetic Oil (after 1000 miles)
Pressure Washed Weekly (not a mod - but shows how clean it is)
AEM Cold Air Intake (Modified)
Optima Red Top Battery (relocated at an angle to let intake run straight down)
Edited 2 time(s). Last edited Thursday, May 20, 2010 4:51 AM
the retainers are found through a member on here...    his name is clyde moore, aka "mitdr774"  he can hook you up with them.
Alright but what about the rest of the parts for the head? Any other upgraded parts for it out there? I'm still looking but at the same time any input from people here is greatly appreciated
Brad: i think clyde only had two sets... and you and me are the ones who got em....
HO cams can be found all day long, and you can ask here how everyone does it with stock retainers...
Parts...
HO Springs - GM - $16 a spring ... Sealed Power - $4 a spring ... (you take your chances reving past 7200 RPM with the sealed power)
1mm SS valves - carcustoms.com
arp head studs - carcustoms.com
HO Lifters - Part stores or GM have these...
you'll need the HO Exhaust cam tower, and you'll need to modify the HO Intake Cam with the PS insert, and CPS pad, and get your housing modified to accept the bigger lifters and cam.
Edited 1 time(s). Last edited Saturday, May 22, 2010 8:20 PM
oh... well nice then
Edited 1 time(s). Last edited Saturday, May 22, 2010 10:16 PM
cool thanks for the help....
Is the melling oil pump better then stock? Or is it just a stock replacement?
for the most part its just a stock replacement.... the best route is to do the 2.3 oil pump swap with a melling pump if you have the resources to do so
I thought someone took apart both pumps and the melling was quite a bit beefier inside.
possibly... but its not as good as the 2.3 pump
