i was able to score some oversized valve springs.with that in mind i was going to replace the valves with the ones off of allecotec.com which are stock replacement. My question is will the stock valves seals and keeper (little pices on top of valve) work or do i have to go aftermarket on them? Any suggestion are helpful
these springs didn't come with new retainers or seats? valve stem seals?
just springs and retainers.
From my limited experience, when you change the valves/valvetrain, chances are you will destroy the stock valve seals/spring seats.  You can get fel-pro replacements on rockauto.com for like 40bucks shipped.
I don't know if you plan on running aftermarket camshafts, but make sure you are wel aware of your new valvesprings' capabilities before installing.
thanks oldskool for the rock auto link found what i need there i plan on have it port and polished, allecotec valves, and
these stage 2 cams from turbo tech racing.
these are the valve springs ill be using specs.
install height 1.375
max spring lift ,550
spring pressure closed 70 @ 1.375
spring pressure open 175 @ 0.0825
coil blind .765
