So I have done the balance shaft removal on the l61. My macining guy polished the crank and so now I have to get bearings. He said  he needs to know the range the mains need to fall into spec wise. I need to know the rod bearing diameter and main bearing diameter. Also the lower crank case bolts say you have to replace them as they are only 1 time use??? God there are 20! Are you guys replacing or reusing then? I call them girdle bolts.
Not sure?!?!?
Thx guys
Jason
Def replace the girdle bolts. unfortunately I dont know the answer to the rest.
 LE61T PTE6262 Powered
Get a hanynes manual, or Chilton it will have this info.
I have both books nothing past bore spec and stock comp ratio
Nevermind found it on clevites website
