So a few thoughts before I get either the pump or the remote start. Maybe you guys can answer this question. The pump needs to to be primed because there is no check valve in the pump and the fuel runs back into the tank. So my question is can you program or add in a time delay module to remote start so the car turns on and primes the pump before starting?
Whats up people?
Most remote starts allow for a time delay start (glow pugs for diesels). The one I have does and can be adjusted though the programming menu on the keyfob / valet switch.
^^^^ what he said remote starters are smarter then humans cause EVERY CAR you should allow it to prime not just the ones with racetronix pumpsi do it in my granp rpix aswell as every car i own
JBO since July 30, 2001
Or maybe put a check valve inline....just a thought
"You can only feed them semen for so long before their legs fall  off."
i have NEVER had a problem with mine priming if i just put the key in and turn it. literally fires right up. no issues what so ever.
