Hey, does anyone have or know where to get a cold air intake for a 97 Cavalier, 2.2?  I can find tons of short ram intakes, but no actual COLD AIR intakes.  I know there are some for the 2.4, would that fit the 2.2?
The question I want to ask is has anyone tried to mod the CAI for the 98+ 2200 to work for the 95-97 2.2?
www.gmofhouston.com
GM_Mike wrote:The question I want to ask is has anyone tried to mod the CAI for the 98+ 2200 to work for the 95-97 2.2?
will be undertaking that task next week, will let you know how it goes.
Thanks Rich, keep us posted.  What system are you using?
I don't see why you couldn't. The part after the first bend after the throttle body should be exactly the same.
Yea I would think it could that easy, but want to make sure first. Keep us informed Rich. It would be so much cheaper to get that intake than what we have available now.
www.gmofhouston.com
The TB is oval shaped right? You may want to try and utilize a piece of the factory hose as the connector between it and the modified intake and use SS clamps on both sides. Unless, of course, you just go out and buy an adaptor.
"In Oldskool we trust"
Mines oval shaped. Just used a coupler.
It is an oval shaped it's not a perfect circle. Although you can use the supplied coupler like Jesse said.
www.gmofhouston.com
Considering the 2.2l has a CAI stock..... just remove the resonator/bong from the bottom of the intake pipe.... put a piece of tube on the end of the intake box so it still goes down into the fender, done.
