I have a 96 2.4 cavalier... I have been looking around on the internet and i figured i would ask you guys because you know a lot about our engines. What are the best or the stronger internals for my car... I will be putting a turbo on it 50 trim. running about 10-12 psi.. i want it to be able to handle 300+ HP... its around 200 right now. I do belive that stock internals are around 270+?. SO just please give me some websites or names for some strong Internals.(Rods,Pistons,Head Steads, and so on) Thanks a lot
I got all my forged internals from Karo at carcustoms.net and also Aaron at turbotechracing.com hooked me up as well.. I got my 2.4 stiffer valve springs from Mantapart..
I have Rods and ARP Head studs for sales, both are brand new and never used, i got them from karo at carcustoms.net. email me if your interested.
i got a 2002 2.4 that im running a 60 trim on and i used the wiseco 9:1 pistons, bored .020 over. eagle h beam rods and arp studs. thats all u need. the stock crank can handle 400 horses easy.
who makes pistons that are .40 over (2.3L bore sized)?
2.3 pistons are way bigger than 2.4 pistons. a 2.4 piston at 0.040 over is not close to the stock bore of a 2.3. You CAN'T bore the 2.4 block to the 2.3 bore. 2.4 pistons are 90mm and the 2.3 are 92mm. It's a 0.080 difference.
Also, All the copmany make the bore you want. It's a custom order so you ask the size you need.
Gilles
2.3 Ho
Brandon Hodge wrote:its around 200 right now.
Not even close to 200hp. You don't have enough modification to get 200hp.
Gilles
2.3 Ho
Mfk-223 wrote:2.3 pistons are way bigger than 2.4 pistons. a 2.4 piston at 0.040 over is not close to the stock bore of a 2.3. You CAN'T bore the 2.4 block to the 2.3 bore. 2.4 pistons are 90mm and the 2.3 are 92mm. It's a 0.080 difference.
My block is at the shop right now getting bore .080 over.....
I know the thread is 4 years old lol
MP-62 Intercooled 2.9" Pulley
LOL at the old ways and myths.
.080 has been done several times by my machinist. its a good idea to sonic test to be sure of wall thickness because different blocks have different core shift but he never did once as far as i know and has never had issues.. ever.
If it takes forever.... I will die trying. Underdog Racing
Piston Wiseco
Eagle Connecting Rods
Clevite Performance bearings
Cometic Head Gasket
ARP Head Studs
is the priceless way...
Boost Lover
lol...wtf ever happened to Gilles? I haven't seen him post in years.
I have no signiture
^^^ ive often wondered that myself.
although... he did have a real condescending attitude and was often a total a-hole.
