Ok maybe someone can help me this time
I have a 2002 cavalier (4door)
Engine is 2.2l
I planning on getting exhaust
What do I need to order so it will all bolt up together.
1. Header
2.  Down pipe
3.  Cat
4.   Catback system
I found some header and down pipe and catback system
But im having a hard time finding a cat that will bolt right up to where the down pipe ends and where the catback exhaust begins
Can anyone help me
I've never seen a full bolt on affair.... Typically you have to weld onto the downpipe a flange if you want to make it bolt on or weld the rest of the system to it.
Also..... Try the search option .... Lots of good info, and no need to make a second thread about the same thing
You could skip the header, get a high-flow cat and do a catback.
RoboticPotPie wrote:You could skip the header, get a high-flow cat and do a catback.
Could, if the stock exhaust manifolds didn't flow like a coffee stirrer.
