im rebuilding a 2200 ovh engine and i need some info on how much torque i need on the bolts when i put it back together ?
Buy a manual ASAP?
Cylinder head bolts
    Step 1
      Short bolts 43 Ft-lbs
       Long bolts 46 Ft-lbs
    Step 2
       Tighten an additional 90 degrees
Cylinder head bolt tightening sequence
        8 4 1 5  9
        7 3 2 6 10
Hope your using new bolts.......
P&P Tuning
420.5whp / 359.8wtq
QWK LN2 (needs an @ss whoopin) wrote:Hope your using new bolts.......
Just why would you do that Ryan ??? Plz tell us
Ooh ooh I know the answer. Head bolts are torque to yield meaning they stretch when they are torqued therefore if you try to torque them again they wont reach full preload and could snap?
^^^^^^^^ DING DING DING DING, YAY!!!!!!
horsepower is the force that determines at what speed you hit the wall, torque is the force that determines how far you take the wall with you after you hit it.
I got a good feeling he was using the original bolts...Guys do they make head studs for the LN2? OP if there are studs available i suggest getting a set. I have them on my eco & they are great.
It beats a Honda!
