Anyone know of a good place to order a copper headgasket for my LD9??
Jason
99 Z24
LG0/LD9 for Life
10 Year Bash Veteren
I ran an SCE Titan ICS head gasket on my turbo saturn, Its extremely important to make sure you retorque the head after the first heat cycle...it will be way loose lol
Also make sure to apply 4~5 coats of Permatex copper coat to it to aid in sealing
Slowzee wrote:I ran an SCE Titan ICS head gasket on my turbo saturn, Its extremely important to make sure you retorque the head after the first heat cycle...it will be way loose lol
what he said, i know its a pita on the ld9, but you have to. mine leaked after like 3 or 4 heat cycle. good after retorque
Get the Cometic mls LD9 gasket and you don't have to worry about it leaking.
my cometic leaked, my sce doesnt leak.... in my opinion, the sce copper is far better. just a pita to retorque
SCE>Cometic  believe me.........buy the SCE you will not be disappointed
ugh....i have a copper one and even an o-ringed block.  I was happy until this retorque thing.
the SCE Titan ICS is not for use with O-Ringed blocks and heads..it has silicone beads around the water jackets and a wire combustion ring
I dont know what brand mine is but it came with the block and already had o-rings.
one thing i found odd about SCE...  they claim that it doesnt matter, you can use the same gasket on either a q4 or an LD9....
 If it takes forever.... I will die trying. Underdog Racing
yes i know, i ordered one and it was for the quad 4, but i'm using a 086 head and only 1 needed to be drill. i have no problem since. havent drive much tho.
i guess you would have to specify when ordering.
i mean only 1 hole needed to be drill
Dale Young wrote:Get the Cometic mls LD9 gasket and you don't have to worry about it leaking.
My block is O-ringed so I need to use a copper gasket
Jason
99 Z24
LG0/LD9 for Life
