I went to take off my crank pulley today and i dont have a big enough socket. I dont want to have to buy a whole set for just one bolt so i was wondering if anyone could tell me what size it is.
Thanks
Well since no one knows what year or motor. How in the hell are we suppose to tell you the correct size?
Stock bolt using a stock crank pulley to stock crank is torqued to 129 lb ft + 90°.
If it is a stock bolt it should be 27mm.  A 1-1/16" socket will work as well.
Since 27mm is 1.0630"
I want to say it was a 7/8 but i believe md here has more experience with crank pullies lol.
Thank you. Since im sure you have dealt with them alot what is the easiest way to get it off? impact gun?
Impact gun is the easiest.  Stick a long screw driver through the pulley, and use a LONG breaker bar works also.  Tightening it to the recommend spec is the hardest part.
chain wrench is the cats ass.
