i have an 03 Sunfire with AEM cold air intake, Pacesetter header and stock everything else. I want to know how much more power i will get by installing a bigger TB?
2,145 hp with a bigger tb
on the high side you might see a max of 0, and on the low side, probably about 0.....
just changing to a bigger tb wont help you... you would have to tune for such...
yup thats why I didn't get one not worth much unless you are having supporting mods to need it.
That would be more beneficial to an engine with a port job and a set of cams.
I agree to disagree. When I upgraded mine, I noticed top end for sure. Whatever people say, my ride got quicker. 4th gear became my best gear when redlining. I only had CAI, exhaust, header and crank pulley at the time. I would get one and when you got enough mods, tune your ride.
Edited 1 time(s). Last edited Tuesday, April 26, 2011 6:13 PM
"FRIENDS DON'T LET FRIENDS DRIVE STOCK"
I have to agree. If it did nothing, then the same should be true of basically any other bolt on.
Has any body used the z spec 62 mm throttle body and their ported intake manifold?
Planning on this setup after the p&p any comments or opinions would be nice
02ECOTECIMPORTKILLER wrote:I agree to disagree. When I upgraded mine, I noticed top end for sure. Whatever people say, my ride got quicker. 4th gear became my best gear when redlining. I only had CAI, exhaust, header and crank pulley at the time. I would get one and when you got enough mods, tune your ride.
Seat of the pants dyno calibrated?
-Trailblazer SS - not so custom 6.0L - custom intake - custom tune
- (1) 2.4L on an engine stand (1) blown trans (2) good quad trans (1) eco trans = party
colt45 wrote:I have to agree. If it did nothing, then the same should be true of basically any other bolt on.
It is true. Bolt on's alone will net you about nothing without a tune.
Mike wrote:colt45 wrote:I have to agree. If it did nothing, then the same should be true of basically any other bolt on.
mikey's right! mikey's right! mikey's right!
Lol... yes. Seat of the pants calibrated! It changed the way the car drove. Highway pulls got way better!
