I am trying to build a n/a LD9. I am having alot of trouble trying to locate high compression pistons! Can you guys help me out?
i don't meanto steal anyones thunder.. best bet is to call wieseco directly...
brodycog wrote:i don't meanto steal anyones thunder.. best bet is to call wieseco directly...
Been there.  After 5 weeks of pure BS and lies from them I went elsewhere.
I think TTR has a set of JE pistons listed.
diamond, wiseco, je, ross, and venoila all make forged LD9 pistons.
All I want... is a little of the good life
yeah its been about 5 weeks for my wieseco pistons now they quoted me april 18th. I called yesterday they were suposed to call me back. they never did.
I have been looking all over, only thing i've come up with is a guy at ROSS Racing will backward engineer them and make whatever you want est turnaround is 6-8 weeks, other than that only used pistons and the 9:1 wiesco that's out there are available nemore.  I think i'm goign to have a set of 10:1 made and then throw a 45 at it... with all the n/a mods to the head I think it will make some good power on 93.
go 11:1 and get valve pockets put in... however making power "on 93" is all in your tune...
yes it is..but as far as running it every day and still running down the track without detonation comes much easier if the compression isn't umm 'over the top' maybe a good word haha, the deck and the head are probably getting a shave when this one comes apart, so 11:1 is going to be pushing the envelope before the boost is even applied as compression would essentially be...don't get all quotie on me but it looks like 11.4:1if not more than that, plus a very real clearance issue with a dome piston....really I just need to hope there is another 62 kit or at least a mani for sale this winter so I can make more than an amazing 8psi or less
i can go back to daily driving mine everyday (after i fix my injectors), and im on wiseco 10.5:1 pistons. with a .020 head shave, .430 lift cams, and 1mm oversized valves... My compression is about 260 PSI across each cyl, and tuned to 93 octane...
I have plenty of clearance... and its actually good to supercharge a high compression motor.  With modern tuning abilities, we are able to get the higher compression and still run 93 octane...
I really wish i had the 11:1 pistons that brad published up on here a couple years ago...
11:1 is not pushing it with today's tuning abilities.  Factory cars come over 11:1 now: Honda S2K 12.4:1, E46 M3 11.8:1, the new BRZ has 12.2:1, the RSX came just over 11:1 from the factory.  All #'s are IIRC, but they should be pretty close.
PSN ID:  Phatchance249
Shawn McKenzie wrote:11:1 is not pushing it with today's tuning abilities.  Factory cars come over 11:1 now: Honda S2K 12.4:1, E46 M3 11.8:1, the new BRZ has 12.2:1, the RSX came just over 11:1 from the factory.  All #'s are IIRC, but they should be pretty close.
My little 1.8L @!#$ shaker is 10.5:1.
well here is the thing without newer designed fuel and head setups don't expect to go over the 11:1 mark easily all out the hondas referenmced run direct inject which puts fuel pressure upwards of 70psi and has an overall better design, so keep that in mind as well, 2013 is def not same as the hardware in the 90's.  I can see 11:1 working, with some doing, for how long? noone knows.
After some thinking and reading and some quik math-balpark stuff- I think 10.5:1 with .010 off the block an 0.20 off the head should be about 11.1, then spin that stupid little mp45, but i don't know how much i trust that 45 in a DD with mo cooling options mite be better off adapting the 62 onto it
Honda just recently started direct injection, however they've been running high comp for years...
once again... Its
ALL IN YOUR TUNE... You can run 12:1 N/A in a J all day long on 93 octane with a good tune, and the motor will last for as long as you maintain it (so long that none of the parts on the motor are defective)..
I echo what Kyle said.  Its all in your tune and parts selection.  Also remember the guys who do the 086 head swap have something like 11.3:1 CR on a STOCK bottom end with no problems when properly tuned.  So if your building the whole bottom end you should have no problem running on 11.5:1 properly tuned, even on a daily driven car.  If I was going to build an NA motor, which I was until 2 weeks ago, I wouldn't go less then 11.5:1.
It all depends on the cams you use that determine what compression you use. Smaller cams as ld9s to the LD2 would be ideal 11-1 or less since the psi would be higher and LG0 or bigger needs higher cr because these cams loose psi in cylinders.
You are wrong.. as your rpms increase with bgger cams so does your compression.  This is how a lot of people use highr cr pistons and shaved heads in circut racing. Because when they do a cr test it won't show high cr on thee test because the valves are overlapping. But at higher rpms there is many things that come into playbut over all your cylnders have more air forced into them.... resonating effect is what ii believe it is called.
Well this is why smaller cams are better with low rpms. They buikd up more tq at lower speeds. But yes dynamic cr is the word I was looking for.. thank you for correcting me. ..
wait what test are we talking about... i have all three of the things listed, and on a compression test, i'm sitting around 260 psi across each cyl...
yeah, i'm leaning to the 11:1 hahaha, but still not sure, I do want to go boosted....even if it is just the limited mp45 thats fine, but it be nice to do more.  Def want pump gas no matter what.  i checked my supposedly stock motor...185 psi across all cylinders, lowest 180-181, odo shows 160k.  but I just don't know yet...with the boost and shaving the head and block....you  guys think that 11:1 are gonna be ok if I end up running 15psi?  I'm only going all out if I get bit by the j-virus again, if not prob just gonna push the mp45-umm whats this max out at again? 8psi? o without getting so hot you can cook on it that is, i'm gonna drive this thing hundreds of miles at a time.
i got some 2.3 made to work in a 2.4 that are cut to raise compression.
97cavalier
