So i just got my header it came with gasket, and 2 bolts for the ball and socket fitting do I use the stock exhaust manifold bolts or what should I use to mount it up to the head?
Also what is the correct assembly of the bolts ,springs and nuts
not sure what you mean about stock bolts but the nuts yes
and put your header on then put your bolts in where the ball joint is, then the down pipe,  springs, washers, then nuts
hope I answered your question right was kinda confused as what you were asking.
if you pm me your # ill send you pics of mine
use the stock STUDS and nuts to mount the header to the head.
