I need a larger fuel pump ASAP.  Racetronix site is down though.  What is a good place to order from?  I need it quick.
Racetronix listed www.lingenfelter.com as a dealer.  Has anyone ever dealt with them?
Thanks
site seems to be fine now, hope you found a solution.
I ended up just getting a Granatelli pump from Jegs.  But I'm still waiting on the FMU to get here.
Did you get a sleeve/foam isolator for it? It will be loose in the pump housing if you didn't. I've been running mine like that for awhile now but if I had to do it again I would definitely grab one from racetronix.
"In Oldskool we trust"
Can't I use the sleeve off the stock pump?
