More powah! - Performance Forum
More powah!
Tuesday, May 17, 2016 5:56 PM
So I just put on my manzo header and decided to do a full on 2.5 custom exhaust ending with a dc sports muffler that has a 3" exit. I'm running a universal cat with the setup as well but no resonator so she is obnoxiously loud so I'm def going to put on a resonator to get that deep and throaty sound. Anyways, I want to make more power so I figured, cams.
Everything else excluding exhaust, intake & motor mounts are currently stock. What cams should I get for my eco? I do not plan to turbo until the motor is built so I have plenty of time. After I do needed repairs I'll be replacing bolts with arp or I'll cam her then replace bolts.
I did search and found a couple mainly through ccw but I'm not too knowledgeable about which ones I should get or if I can get them cheaper. I'll be doing the 2.4 intake mani/tb swap as well as bsd but nothing too extreme for quite some time.
TL;DR?
Cam part numbers needed for stock 2.2 eco for moar powah.
Re: More powah!
Wednesday, May 18, 2016 12:18 AM
Comp Cams Stage 2 with Supertech valve springs. You need better valve springs when you upgrade cams.
You will also need a set of LSJ fuel injectors and have the car tuned.
Re: More powah!
Thursday, May 19, 2016 8:26 PM
Awesome thanks, also do you know if http://www.rksport.com/product-p/rk-483.htm that would be a worthwhile upgrade? Anyone running them or have ran them know of they are worth it? I use NGK g power plugs
Re: More powah!
Friday, May 20, 2016 6:45 AM
Those are not worth it. I ran a set of them and the butt dyno felt nothing.
Re: More powah!
Friday, May 20, 2016 3:57 PM
Ah okay, guess if I want an ignition upgrade I'd have to do a conversion or something.
Re: More powah!
Sunday, May 22, 2016 6:02 AM
As for the ignition springs. It is something your not going to feel. Just like valve springs. You do not gain power from them, but they are needed.
Re: More powah!
Sunday, May 22, 2016 5:37 PM
So what do they accomplish then if no power is gained?
Re: More powah!
Thursday, May 26, 2016 5:49 PM
The best word I can think of is stability. A higher conductor of electricity would mean a sure spark. Bigger spark isn't gonna do anything but make sure you have enough spark not to misfire. So no gains just a hopeful for constant stability.
Re: More powah!
Thursday, May 26, 2016 9:40 PM
Hmm, I have been experiencing random misfires(p0141) lately. How does one install these? Just slide them in the coils? I'm going to change plugs and if the misfires still persist I guess I'll give these a try. Maybe.
Re: More powah!
Thursday, May 26, 2016 10:32 PM
Side note/curiosity, what about spark plug "side gapping?" i read theres suppose to be a decent gain to doing this mod but has anyone here done it? Worth it? and does it change the lifespan of the plugs?
ReD RaiN
Re: More powah!
Thursday, May 26, 2016 11:04 PM
http://performanceunlimited.com/documents/plugsidegapping.html
That seems like an interesting modification, I also would like to hear if you guys have done this before.
