Suspension/wheels will get this car looking great again! I built this car last season in 6 months, touching everything possible, and spending a ton of money not to mention hours doing such. Trust me, I'll be nothing but honest about this car.
Car has gotten much positive attention in one season-
2007 South Haven Festival of Car - Best 1990-present
2007 GM Tuner Bash - Third Gen - 1st Place Mild
2007 GM Tuner Bash - 4th place Quick 8 N/A
2007 Coloma/Glad Peach Car Show - Best 1990-1999
2007 SWMI Hispanic/Lowrider Show- 1st Place Euro Imp./Dom.
March feature in jbodysource.com/j-body.org calendar
Details-
1997 Chevrolet Cavalier Z24
2.4l DOHC, 5 speed
94,xxx miles
The good-
Engine:
SPEC Stage II clutch
Fidanza lightened flywheel
2.3HO intake manifold (powdercoated silver)
Fontana Performance 2.3-2.4 phenolic adapter flange
56mm HO throttle body
AEM Ecotec CAI w/Dryflow filter (powdercoated silver)
Pacesetter 4-1 stainless header
Megan Racing NA Type stainless cat-back exhaust
Catco high-flow converter
Prothane upper engine mount insert
Prothane lower engine mount
Prothane transmission mounts
B&M short throw shifter
billet underdrive crank pulley
A/C delete pulley
Optima Red-Top battery (brand new, have receipt)
Suspension/Wheels/Brakes:
Eibach 26mm front swaybar
Prothane control arm bushings
drilled/slotted rotors
Hawk pads
Interior:
2k+ full dash swap
2k+ center console
all panels/carpet swapped out for graphite pieces/replaced
2002 LS Sport front seats/rear seat/door panels
Tenzo R Turismo steering wheel
MOMO steering wheel hub
Lotek triple pod
Autometer Ultra-Lite Oil Pressure gauge
Autometer Ultra-Lite Voltmeter gauge
brushed aluminum gauge bezel
OEM cluster needles painted orange to match Autometer gauges
cluster converted to red LED lighting
Sunfire GT HVAC panel/window switch
leather B&M shift knob
Exterior:
custom paint/full restore (Toyota Catalina Blue Metallic)
RKSport ram-air/98SS style hood
RKSport Import Fighter front bumper
RKSport Import Fighter sideskirts
'03+ LS Sport rear bumper w/shaved Chevrolet
shaved door handles/locks
shaved gas door w/filler relocated into trunk
shaved trunk lock
shaved antenna
painted mirrors
Toyota Cavalier corner lenses
base model amber bumper lenses
black projector headlights
2k+tails
disabled DRL's
20% tint front/rear
Toyota Cavalier 2.4Z emblem (red)
Audio:
Pioneer DEH-P5800MP WMA/MP3/CD player
Pioneer 3-way 6x9’s
StreetWires fused battery terminal (BT2PF)
StreetWires distribution block
StreetWires 1/0 gauge/4 gauge wiring
Miscellaneous:
Viper alarm
Spal Amenity shaved door kit
remote trunk release
remote power windows down
Maintenance-
Mobil 1 used since I bought it, flushed engine before first change
new rear main seal, gasket, and axle seals all done last year
tranny flush, now has Synchromesh in it
new fuel filter/o-rings/connect fitting
new NGK plugs
new reverse light switch
both p/window motors replaced last fall with remans
sure there's a little more I'm forgetting
The "bad"?-
-minor damage from fender rolling (pics couldn't even capture, you can just tell around the lip where it's rolled ever so slightly, minor
-very small crease on driver's fender...paint reflection wouldn't allow camera to even pick it up)...
-spots along door molding (still minor IMO)
-no airbags, A/C, nor cruise control
-driver's p/mirror not working for some reason (worked before disassembly/paint)
-CEL from EGR removal, have scanner and can prove that's all it is...does not affect car one bit
-steelies and stock suspension!
Pics from this past season-
Current pics-
-NOTE THE CAR IS NOT DRIVEN IN WINTER, just pulled it out for pics
-RKSport ram-air hood will be on car, bodyshop has it for paint as we speak
-sideskirts above are still included, just took them off as the 3M tape wasn't holding
-my other half is in Oklahoma with the camera, hence the crappy cell phone pics
 $3800 FIRM!
$3800 FIRM!  I think it shows I easily have that invested, heck I have that into paint/bodywork alone.
95-99 Toyota tails can also be reinstalled if desired.
Edited 1 time(s). Last edited Wednesday, February 20, 2008 5:29 PM
