I have the following parts for sale...
Located in GTA / Mississauga.
2.3 HO Intake Manifold $100
GM part # 22538691. I think I have the throttle body somewhere too, just need to look for it, but If I find it, it's included too.
2.4 Complete Head $80
Not sure of the mileage of this part, I bought it from a wreckers
2,4 Exhast Manifold and Downpipe $40
Manifold is ported, gasket matched on the head flange and ported to 2.25" on the collector side, runners are smoothed out as far a possible. The down pipe is a peice that I had custom made from mandrel bends. It's 304 stainless with a flex joint. There is also a 2.25"flange/pipe included (with bung for the 2nd O2 sensor) that will allow this thing to bolt up to the factory (or aftermarket) catback, just stick a 2.25" cat in between them....
I also have a completely stock exhaust manifold, $20 if anyone wants it
2.4 OEM Clutch and Flywheel $50
I took them out of the car @ 100,000 KM when I installed the Fidenza/SPEC combo, they worked perfect at the time and the disc has lots of meat left on it.
2.4 OEM downpipe $10
Yes it's cracked at the flex joint, but someone may be looking for an OEM cat.
Ford/Mazda Intercooler $80
Taken from an early 90's turbo Probe
Audi Intercooler $80
If I remember correctly this came from an Audi 5000, not sure of the year.
hey just wondering if you still have the intake manifold and if you were able to find the throttle body. where exactly are you located? im quite interested.
I got my PORT matched HO mani and TB for 60 $... I think the price is a tad steep.
My Cav
I give up...
that H.O. intake, I got at the wrecker for $35, your price is way to high.
RESPECT A MAN"S RIDE AND HE WILL RESPECT YOU.
matt ill take the manifold and throttle body if you come up with the ownership for the car you said you found.
I found a "High Output" IDI Cover that I had stashed away in the garage $50 obo. I'll get a picture of it later, but it was sandblasted clean and then painted transparent red.
I also have a 2.4L throttle body. It is bored out to 56mm from the stock 52mm. $150 obo I'll get pics of that up as well.
do you have a throw out bearing to go with that clutch set?
megatron wrote:do you have a throw out bearing to go with that clutch set?
Dont bother man, its for a 95-99, not 2000+
my car is going to need a clutch soon... im debating buying this one and giving it to the new buyer with the car, installation is jsut so expensive...
"Louis, you better watch who you call a child. Because if I'm a child,
that makes you a pedafile, and I'm not gonna stand here and argue
with a pervert" -- Peter Griffin
ill give you $100 for the manifold and the idi cover and if you find the 2.3 TB ill give you an extra 25$ im just sick of looking around for the ones i want. thanks , alex
Considering
I'm offering a 62mm throttle body for $150, you'll be better suited asking $100 or so for your 56mm...
14.330 @ 96.37mph
Alex P, I sent you a PM.
My Cav
I give up...
Another part that I never got around to installing......
A set of RK Sport braided stainless steel front brake lines (with new OEM copper washers for installation) $50 obo
