I need this (still), its the crank sensor and wiring. Its an 8mm bolt, and is located right above the starter and underneath the oil press sensor. Its hidden a bit but its there
HAS to be a cobalt 06+ that has the 3-wire Hall-effect sensor.
Pontiac Fiero powered by L61/LE5 Ecotec "Innovation is a new level of performance"
Shouldn't but I think only the LE5/L61 use the Hall-effect. You can simply check by the wire count. VR sensor is 2 wire and Hall-effect is 3.
If you pull it PLEASE PLEASE PLEASE grab at least that wiring or cut farther up the line. I will pay
